Regarding the thermostat, I've noticed a change in the status of the actuator.
Previously, this On/Off switch was either On or Off.
Now, with version 2025.1, it has changed to a Contact switch that can be either Open or Closed.
As a result, the scripts need to be adjusted.
More concerning, and even somewhat illogical, is that when the thermostat calls for heat (shown on the Netatmo UI by flames), the actuator in Domoticz is in the Open state.
An Open contact is not closed and is not considered On by definition.
Before posting an issue on GitHub, can those of us who have version 2025.1 confirm my observations?
[2025.1] Problem with Netatmo thermostat
Forum rules
Version: xxxx
Platform: xxxx
Plugin/Hardware: xxxx
Description:
Version: xxxx
Platform: xxxx
Description:
- Domoticz version: 2024.7
