2025.1 zigbee2mqtt python plugin needs update Topic is solved
Forum rules
Version: xxxx
Platform: xxxx
Plugin/Hardware: xxxx
Description:
THBR
Post by THBR »
Just did the upgrade Domoticz from v2024.4 to 2025.1. Everything went fine and Domotciz/all devices work as usual, but the Zigbee2mqtt ui page keeps loading. Thought of a (firefox) cache issue, but clearing the cache or browsing in private mode didn't resolve it.
Before the upgrade (under v2024.4) I had no problems al all. Besides the upgrade I haven't changed anything.
Any ideas?
My configuration:
RaspberryPi 3b
Booting/operating from 64 GB USB-flashdevice, no SD card
Raspbian GNU/Linux 10 (buster)
Domoticz version: Upgraded on 7-5-2025 from v2024.4 to 2025.1
Python Version: 3.7.3
Zigbee2mqtt plugin (by stas-demydiuk): v.3.2.0-beta
Zigbee2mqtt: v1.42.0 (zStack3x0 20211114)
Zigbee Slaesh's CC2652RB coördinator USB-dongle
TinyTUYA Plugin version 2.1.8
RTC DS1307
THBR
Re: Domoticz version 2025.1 released
Post by THBR »
Sorry, wrong sub forum..
Problem, solved!
But in the meantime my problem has been solved: after a "git pull" of the plugin, everything worked again, sorry.
Edit waltervl: moved to correct subforum
wojtech
Domoticz version: 2025.1
Re: 2025.1 zigbee2mqtt python plugin needs update
Post by wojtech »
I have the same problem, can you write what is the exact line command to update phyton.
Wojtek
Domoticz version: 2024.7
In the plugin repository readme is an update section: https://github.com/stas-demydiuk/domoti ... qtt-plugin
