Time function is not executed
Backbone
Domoticz version: 2023.2
Post by Backbone »
I wrote a script for a thermostat that worked fine for 6 months.
Suddenly the time function is not executed anymore.
Nothing to be shown in the log when a time period is activated.
Only when I manually trigger the object where this timer is residing in from OFF to Normaal or vice versa it changes and the log reports the status change.
Simpel code...........
if  dz.time.matchesRule('at 00:00-05:44') then
dz.devices(74).updateText ('00:00-05:44 @ 16.5 C - preset')
dz.log ('It works')
It must be simple as the script ran flawless and I did not change the code.
I cant remember Domoticz has been updated and this is the result.
Full code.........
return
        --Thermostaat           -- =idx69   thermostat controller
        --CV_Brander            -- =idx67   cv burner switch
        --Temp_Kamer            -- =idx32   room temperature
        --Setpoint_Normaal      -- =idx68   regular temperature setpoint
        --Setpoint_Boost        -- =idx72   boost temperature setpoint
        --Setpoint_Boost_Tijd   -- =idx75   boost time
        --Thermostaat_Status    -- =idx74   textbox
    on =
        devices = {'Thermostaat', 'CV_Brander', 'Temp_Kamer','Setpoint_Normaal','Setpoint_Boost','Setpoint_Boost_Tijd' },
    execute = function(dz)
        local varTempReg = dz.variables('varTempReg') --declared as float value in settings menu
        varTempReg = dz.devices(68).setPoint
        -- "Uit" mode active, initiated by thermostat switchselector at level 0
        if dz.devices(69).level == 0 then
           dz.devices(67).switchOff().checkFirst()
           dz.devices(74).updateText ('Thermostaat OFF')
           dz.log('Thermostat OFF')
-- mon to thu
        -- "Normaal" mode active, initiated by thermostat switchselector at level 10
        if  dz.time.matchesRule('on mon,tue,wed,thu') then
            if dz.devices(69).level == 10 then
                if dz.devices(32).temperature < 16.5 then
                    dz.devices(67).switchOn().checkFirst()
            if  dz.time.matchesRule('at 05:45-06:29') then
                dz.devices(74).updateText ('05:45-06:29 @ 16.5 C- preset')
            if  dz.time.matchesRule('at 06:30-16:59') then
                dz.devices(74).updateText ('06:30-16:59 @ '..varTempReg..' C instelbaar')
                if dz.devices(32).temperature < dz.devices(68).setPoint then
            if  dz.time.matchesRule('at 17:00-19:29') then
                dz.devices(74).updateText ('17:00-19:29 @ 18 C - preset')
                    if dz.devices(32).temperature < 18 then
            if  dz.time.matchesRule('at 19:30-23:59') then
                dz.devices(74).updateText ('19:30-23:59 @ 16.5 C - preset')
end -- mon to thu
--fri to sun
    if dz.time.matchesRule('on fri,sat,sun') then
            if  dz.time.matchesRule('at 00:00-07:29') then
                    dz.devices(74).updateText ('00:00-07:29 @ 16.5 C - preset')
            if  dz.time.matchesRule('at 07:30-16:59') then
                dz.devices(74).updateText ('07:30-16:59 @ '..varTempReg..' C instelbaar')
                dz.devices(74).updateText ('17:00-19:29 @ '..varTempReg..' C instelbaar')
    end --fri to sun
Re: Time function is not executed
What Domoticz version are you currently on (see menu Setup - About)
For me it works.
I modified your simple code to get it to work on evenings
		timer = {
			'every minute',
	logging = {
		level = domoticz.LOG_INFO,
		marker = 'timertest',
	execute = function(domoticz, timer)
	  domoticz.log('Timer event was triggered by ' .. timer.trigger .. 'at time : ' .. domoticz.time.raw, domoticz.LOG_INFO)
	  if  domoticz.time.matchesRule('at 00:00-18:44') then
               -- dz.devices(74).updateText ('00:00-17:44 @ 16.5 C - preset')
               domoticz.log ('It works at time :'.. domoticz.time.raw)
Then in the log I see this:
2025-04-30 18:43:00.069 dzVents: timertest: Timer event was triggered by every minuteat time : 2025-4-30 18:43:0.45
2025-04-30 18:43:00.069 dzVents: timertest: It works at time :2025-4-30 18:43:0.45
And after 18:44 i do not get the "It works" log entry as expected.
Perhaps something off with your time on your server?
Backbone
Post by Backbone »
Hello Walter,
Thanks for testing, so it must be in my setup.
Domoticz:
Version: 2024.7
Build Hash: b317cfab1
Compile Date: 2024-07-13 16:59:31
dzVents Version: 3.1.8
Python Version: 3.9.2 (default, Mar 12 2021, 04:06:34) [GCC 10.2.1 20210110]
Active User: admin
I thought about the summer/winter time but then it would give a 1 hour difference only.
I run domoticz on a Pi. No idea where to check the time you refer at.
Paco
Backbone
Post by Backbone »
put your code in and that works. I get the logs.
2025-05-01 06:53:00.179 dzVents: timertest: Timer event was triggered by every minuteat time : 2025-5-1 6:53:0.52
2025-05-01 06:53:00.179 dzVents: timertest: It works at time :2025-5-1 6:53:0.52
But the trigger is on every minute.
My original trigger is
    on =
It worked before.
Is my assumption of how DZ works wrong?
In your case whenever one of the mentioned triggered devices is changed (by the integration or by the user interface or other scripts) the main script will run.
So if you do not see the script running at all then something has changed in changing the devices.
Also dzvents likes unique device names, so for example no 2 different devices with the same name "Thermostaat"
