P1 multigraph - no data coming in?
renerene
Post by renerene »
my P1 muligraph is not working anymore. Used to work months ago. Device has not changed, same IDX (427)
Even tested the code principle from the read-the-docs
Result: no lines, no data. Here is the screenshot from the </>show data hamburger menu:
//based on https://dashticz.readthedocs.io/en/beta/blocks/graphs.html#custom-graphs
blocks['multigraph_427'] = {
    title: 'My Power',
    devices: [427],
    graph: ['line','bar','bar'],
    custom : {
        "last day": {
            range: 'day',
            filter: '24 hours',
            data: {
                nett: 'd.v_427+d.v2_427-d.r1_427-d.r2_427',
                usage: 'd.v_427+d.v2_427',
                generation: '-d.r1_427-d.r2_427'
        "last 2 weeks": {
            range: 'month',
            filter: '14 days',
            data: {
        "last 6 months": {
            range: 'year',
            filter: '6 months',
            data: {
    legend: true,
    datasetColors:['blue','red','yellow']
Lokonli
Re: P1 multigraph - no data coming in?
Post by Lokonli »
Domoticz changed.
Replace d.v_427 with d.v1_427
renerene
Post by renerene »
Lokonli wrote: Monday 28 April 2025 22:25 Replace d.v_427 with d.v1_427
No, that does not work:
    title: 'My Power',
    devices: [427],
    custom : {
        "last day": {
            range: 'day',
            filter: '24 hours',
            data: {
                nett: 'd.v1_427+d.v2_427-d.r1_427-d.r2_427',
                usage: 'd.v1_427+d.v2_427',
        "last 2 weeks": {
            range: 'month',
            filter: '14 days',
            data: {
        "last 6 months": {
            range: 'year',
            filter: '6 months',
            data: {
    legend: true,
Json dump:
	"ActTime" : 1745912962,
	"AstrTwilightEnd" : "23:19",
	"AstrTwilightStart" : "03:50",
	"CivTwilightEnd" : "21:33",
	"CivTwilightStart" : "05:36",
	"DayLength" : "14:42",
	"NautTwilightEnd" : "22:21",
	"NautTwilightStart" : "04:48",
	"ServerTime" : "2025-04-29 09:49:22",
	"SunAtSouth" : "13:34",
	"Sunrise" : "06:13",
	"Sunset" : "20:55",
	"app_version" : "2024.7",
	"result" :
			"AddjMulti" : 1.0,
			"AddjMulti2" : 1.0,
			"AddjValue" : 0.0,
			"AddjValue2" : 0.0,
			"BatteryLevel" : 255,
			"Counter" : "48837.268",
			"CounterDeliv" : "28909.955",
			"CounterDelivToday" : "0.109 kWh",
			"CounterToday" : "1.760 kWh",
			"CustomImage" : 0,
			"Data" : "33917776;14919492;8214093;20695862;83;0",
			"Description" : "",
			"Favorite" : 1,
			"HardwareDisabled" : false,
			"HardwareID" : 16,
			"HardwareName" : "stroommeter-USB1",
			"HardwareType" : "P1 Smart Meter USB",
			"HardwareTypeVal" : 4,
			"HaveTimeout" : false,
			"ID" : "0001",
			"LastUpdate" : "2025-04-29 09:49:16",
			"Name" : "Stroom",
			"Notifications" : "false",
			"PlanID" : "0",
			"PlanIDs" :
				0
			"Protected" : false,
			"ShowNotifications" : true,
			"SignalLevel" : "-",
			"SubType" : "Energy",
			"SwitchTypeVal" : 0,
			"Timers" : "false",
			"Type" : "P1 Smart Meter",
			"TypeImg" : "counter",
			"Unit" : 1,
			"Usage" : "83 Watt",
			"UsageDeliv" : "0 Watt",
			"Used" : 1,
			"XOffset" : "0",
			"YOffset" : "0",
			"idx" : "427",
			"price" : "0.4171"
	"status" : "OK",
	"title" : "Devices"
renerene
Post by renerene »
problem solved
found the correct data field names using
columns[3]['blocks'] = ['graph_427'];
maybe the rename issue had something to do with filling in the cost fields in DZ settings
Lokonli
Post by Lokonli »
Good, thanks!
You have a single tariff meter I assume?
My P1 meter gives v1, v2 and r1,r2 values.
I'm working on an update of the graph module, so that the default graphs will be dependent on the device type and will give more useful graphs by default. For P1 meters I'll include the detection of single tariff and double tariff meters.
