Log does not work if events do not change Topic is solved
Forum rules
Version: xxxx
Platform: xxxx
Plugin/Hardware: xxxx
Description:
Version: xxxx
Platform: xxxx
Description:
Jemand
It seems that domoticz is not updating the Log for a device if the action is the same. I have a button which sends "single", "double", "hold"... events. If I click "single" the action is triggered correctly and everything is working but the log doesn't update if the last click was also the same event (in this case "single"). Is there any way to log the same events?
- Domoticz version: 2025.1
Re: Log does not work if events do not change
I have such device that is updated by a python plugin (Zigbee4Domoticz) and then I see for example every double click action being logged.
What kind of integration do you use?
- HansieNL
Have you checked the Log History settings?
There's a setting: Only add newly received values to the Log
Blah blah blah
Jemand
Yes, there is no change in the log if I enable or disable this setting. What I currently think is: I could set a different event to that switch when I performed my action to kind of reset it for the next click.
Jemand
Integration is through Zigbee2MQTT Plugin (v. 3.2.0-beta). I now have solved the issue by the state back to "off".
Users browsing this forum: mojso and 1 guest
