Page 1 of 2
Dashticz v3.14.1-beta
Posted: Tuesday 25 March 2025 18:46
by Lokonli
After some silence a new Dashticz release v3.14.1-beta!
This release focuses on changes in the handling of Domoticz device blocks.
Besides quite some internal code changes, this release also brings new functionality:
- Combine multiple values of a device into one block (for instance multiple values of a P1 Smart Meter)
- Combine device values of multiple devices into one block
- combine.jpg (6.71 KiB) Viewed 3181 times
- p1_multiline.jpg (18.27 KiB) Viewed 3181 times
Changes have been documented in the
Release Notes
For the users that make use of 'getExtendedBlockTypes' code hook: check the
update notes
Re: Dashticz v3.14.1-beta
Posted: Wednesday 26 March 2025 1:16
by solarboy
Excellent, thank you, shall try it now.
Posted: Wednesday 26 March 2025 9:44
by TroisSix
Nice feature, will try this soon.
Thank you Lokonli ^^
Posted: Sunday 06 April 2025 10:40
by madpatrick
Hi Lokonli,
I noted the following during update to 3.14.1 beta.
The group icons are overruled
blocks[gr_tuin] = {width: 2, hide_data : true, last_update : false, image: 'patrick/blue_garden.png', title:'Tuin'}
blocks[gr_kamer] = {width: 2, hide_data : true, last_update : false, image: 'patrick/blue_desk_lamp.png', title:'Kamer'}
- 2025-04-06 10_33_06-Dashticz.png (49.67 KiB) Viewed 2841 times
- 2025-04-06 10_33_24-Dashticz.png (51.45 KiB) Viewed 2839 times
With the Logitech Media server i had a empty line when switched off, but his now giving a text
blocks['lms'] = {idx: 480, width : 8,iconOn: 'fas fa-volume-down fa-beat', iconOff: ' '}
- 2025-04-06 10_35_52-Dashticz.png (4.1 KiB) Viewed 2839 times
The block heights are now overrruled from my .css file
The mouse over is correct, but the normal block height is not smaller
/* --------------------------------------------------------------------------- BLOCKS */
.transbg.col-xs-1,
.transbg.col-xs-2,
.transbg.col-xs-3,
.transbg.col-xs-4,
.transbg.col-xs-5,
.transbg.col-xs-6,
.transbg.col-xs-7,
.transbg.col-xs-8,
.transbg.col-xs-9,
.transbg.col-xs-10,
.transbg.col-xs-11,
.transbg.col-xs-12 {
padding-top : 8px;
padding-bottom : 6px;
border : 2px solid rgba(255,255,255,0);
border-radius : 1px;
background : rgba(77,77,222,0.2);
background-clip : padding-box;
height: 100px ;
text-align : center !important;
/* --------------------------------------------------------------------------- On mouse-over */
.transbg.col-xs-1.hover:hover,
.transbg.col-xs-2.hover:hover,
.transbg.col-xs-3.hover:hover,
.transbg.col-xs-4.hover:hover,
.transbg.col-xs-5.hover:hover,
.transbg.col-xs-6.hover:hover,
.transbg.col-xs-7.hover:hover,
.transbg.col-xs-8.hover:hover,
.transbg.col-xs-9.hover:hover,
.transbg.col-xs-10.hover:hover,
.transbg.col-xs-11.hover:hover,
.transbg.col-xs-12.hover:hover {
padding-top : 8px;
height: 100px ;
font-size: 26px !important;
Posted: Thursday 10 April 2025 7:40
by Lokonli
ok, thanks for testing.
Last minute I had added a small bugfix, which unfortunately has some side effects.
It's a signal however that the code has become too complex, and that the current approach of manual testing is not sufficient anymore.
So, i decided to:
1) Implement an automatic testing framework. The idea is that all examples in the Dashticz documentation will be tested after every change. I've implemented the first 5 tests at the moment.
2) Another redesign of the software code for handling the Domoticz devices.
Next update will follow soon.
Posted: Wednesday 16 April 2025 7:53
by Renber
Since the April 15 update, I've lost my icons on LightSwitch devices (whether switches, doors, or IR sensors). FYI: I don't have any "icon:" parameters in my JS; I'm using the default icons.
Thanks.
Posted: Friday 18 April 2025 14:00
by Lokonli
Renber wrote: Wednesday 16 April 2025 7:53
Thanks.
Can you test latest version? (3.14.1.3, 17-4)
It should work now.
Posted: Friday 18 April 2025 16:39
by Lokonli
madpatrick wrote: Sunday 06 April 2025 10:40
Hi Lokonli,
.transbg.col-xs-1,
.transbg.col-xs-2,
.transbg.col-xs-3,
.transbg.col-xs-4,
.transbg.col-xs-5,
.transbg.col-xs-6,
.transbg.col-xs-7,
.transbg.col-xs-8,
.transbg.col-xs-9,
.transbg.col-xs-10,
.transbg.col-xs-11,
padding-top : 8px;
height: 100px ;
padding-top : 8px;
height: 100px ;
I had to change the CSS classes slightly because in the new Dashticz version a Domoticz block can consist of multiple lines, meaning the height of a block should be able to grow.
You can change your styling to:
.transbg {
background-color : rgba(77,77,222,0.2) !important;
padding-top : 8px !important;
padding-bottom : 6px !important;
border : 2px solid rgba(255,255,255,0) !important;
border-radius : 1px !important;
.mh {
height: 100px !important;
.transbg.hover:hover {
Posted: Friday 18 April 2025 17:41
by Lokonli
Probably fixed in 3.14.4.
Can you test? (I don't have a LMS)
Posted: Friday 18 April 2025 20:12
by Renber
It should work now.
It's good for me. Thank you for your work.
Posted: Friday 18 April 2025 20:42
by madpatrick
Hi Lokonli,
Thanks for the update.
It looks better now, but not all good for me yet.
Probably some setup issues which need to sort out.
The block are good now and needs a little bit tweaking
The LMS text is now ok, but needs a bit more testing when the music is playing
[EDIT]
The LMS text is ok
The standby screen is now mangled
[EDIT]
THe problem looks to appear in the TEXTBLOCK
Old version
- Standby-old.png (44.8 KiB) Viewed 2485 times
New version
- Standby-New.png (47.59 KiB) Viewed 2485 times
/* --------------------------------------------------------------------------- STANDBY BACKGROUND --------------------------------------------------------------------------- */
.screenstandby {background-color: black !important}
/* --------------------------------------------------------------------------- STANDBY SCREEN --------------------------------------------------------------------------- */
.standby .block_textblock1 {height: 150px !important;background-color: rgba(0,0,0,1) !important;text-align: left !important}
.standby .block_textblock1 .title {display: none !important}
.standby .block_textblock1 .value {font-size: 22px !important;color:white !important; display:inline-block;position: relative; left: -50px !important;top: -15px !important;}
.standby .block_textblock2 {height: 150px !important;background-color: rgba(0,0,0,1) !important}
.standby .block_textblock2 .title {display: none !important}
.standby .block_textblock2 .value {font-size: 22px !important;color:white !important;text-align: center !important;top: -15px !important;}
.standby .block_textblock3 {height: 150px !important;background-color: rgba(0,0,0,1) !important}
.standby .block_textblock3 .title {font-size: 26px !important;position: fixed;top: 5px;right: 10px;text-align: right !important;text-shadow: 2px 2px 5px #FF0000 !important}
.standby .block_textblock3 .value {font-size: 22px !important;position: fixed;top: 40px;right: 5px;text-align: right !important;}
.standby .block_textblock3 img {position: fixed;top: 8px;right: 135px;text-align: right !important;max-width: 30px !important;}
.block_textblock2 .value {font-size: 22px !important;color:white !important;display:inline-block;position: relative;top: -15px !important;}
.standby [data-id='myclock'] {height: 150px !important;background-color: rgba(0,0,0,1) !important;}
.standby [data-id='myclock'] .clock-day {color: rgba(250, 190, 190, 1) !important;text-shadow: 4px 3px 3px #8c8c64 !important;font-weight: bold !important;}
.standby [data-id='myclock'] .clock-hours {color: rgba(242, 242, 242, 1) !important;}
.standby [data-id='myclock'] .clock-minutes {color: rgba(242, 242, 242, 1) !important;}
.standby [data-id='myclock'] .clock-seconds {color: rgba(179, 179, 179, 0.6) !important;}
.standby [data-id='myclock'] .clock-label {color: rgba(200, 200, 0, 1) !important;font-weight: bold;font-family: "floydian"}
.standby .block_regen {font-family: Arial !important;height: 180px !important;display:flex;align-items:center;text-align: right !important;background-color: rgba(0,0,0,1) !important}
.standby .block_regen .title {font-size: 30px !important;rgba(244, 255, 204, 0.5) !important;}
.standby .block_regen .value {display: none}
.standby .block_regen img {display: none}
.standby [data-id='weather_standby'] {font-family: Arial !important;height: 180px !important;background-color: rgba(0,0,0,1) !important}
.standby [data-id='weather_standby'] .icon {font-size: 24pt !important;padding-left: 10px !important}
.standby [data-id='weather_standby'] .temp {font-family: Arial !important;font-weight: bold;font-size: 26pt !important;color:#f4ffcc;}
.standby .weather .icon {max-width: 80px !important;}
.standby .weather .temp {font-family: Arial !important;font-weight: bold;font-size: 26pt !important;color:#f4ffcc;}
.standby .block_sunrise {height: 80px !important;display:flex;align-items:center;text-align: center !important;background-color: rgba(0,0,0,1) !important}
.standby .wi-sunrise:before {font-size: 32pt !important; color: yellow; !important;padding-left: 40px !important;}
.standby .wi-sunset:before {font-size: 32pt !important; color: orange !important; padding-left: 30px !important;}
.standby .sunrise {font-size: 30pt !important; color: #f4ffcc !important;padding-left: 20px !important;}
.standby .sunset {font-size: 30pt !important; color: #f4ffcc !important;padding-left: 20px !important;}
.standby .block_lms {height: 150px !important;display:flex;align-items:center;text-align: left !important;padding-top: 100px !important;background-color: rgba(0,0,0,1) !important}
.standby .block_lms .icon {max-width: 40px !important;color: #89CCFF !important}
.standby .block_lms .col-data {color : yellow !important;display:flex;align-items:center;text-align: left !important;}
.standby .block_lms .title {display: none}
.standby .h4.h4 {font-size:22px;}
Posted: Friday 25 April 2025 6:59
by Renber
since the update I have lost the domoticz blocks that had a space in their name. I resolved this by replacing the space with "_".
Posted: Friday 25 April 2025 19:56
by Lokonli
madpatrick wrote: Friday 18 April 2025 20:42
Hi Lokonli,
[EDIT]
The LMS text is ok
[EDIT]
Old version
New version
I expect these issues have been solved in latest version.
Could you retest?
Posted: Friday 25 April 2025 20:02
by Lokonli
Renber wrote: Friday 25 April 2025 6:59
I cannot reproduce the problem.
Can you send me:
1. your block definition from CONFIG.js
2. the json output of the Domoticz device:
http://domoticz-ip:port/json.htm?type=command¶m=getdevices&rid=123
with 123 your device id.
Posted: Friday 25 April 2025 20:04
by madpatrick
Looking good.
Thanks for the swift fix
Posted: Friday 25 April 2025 20:40
by madpatrick
Hi Lokonli,
Found another issue
My sliders are gone
.ui-slider-handle {padding: 6px 10px 6px 10px !important;background-color: #00aaff !important;border-color: white !important;border-radius: 14px;height: 22px !important;width: 48px !important;box-shadow: inset 3px 3px 5px 0px rgba(255,255,255,0.5)}
.ui-slider-horizontal {background-color: #6a6a6a !important;border-color: #ffffff;max-width: 85% !important;}
- 2025-04-25 20_39_32-Dashticz.png (107.08 KiB) Viewed 2078 times
- 2025-04-25 20_40_06-Dashticz.png (97.69 KiB) Viewed 2078 times
Posted: Saturday 26 April 2025 11:28
by Lokonli
madpatrick wrote: Friday 25 April 2025 20:40
Hi Lokonli,
Found another issue
My sliders are gone
Fixed in latest version.
I've slightly changed (improved) the CSS definition of the stop button, to make the height 100% correct.
You may have to adjust your css styling as well a bit.
Posted: Saturday 26 April 2025 11:34
by madpatrick
Thanks for the quick fix.
How can i adjust the stop button ?
.btn-number.stop {width: 88px !important;height: 50px !important; border: 1px solid rgba(255,255,255,0.7);background: red; border-radius: 5px;font-size:20px !important;}
When i change the size it doesn't work
Posted: Saturday 26 April 2025 12:11
by Renber
Can you send me:
is ok:
blocks['VLC_Bureau'] = {idx:1386,width:12,title:'VLC'};
is not ok:
blocks['VLC Bureau'] = {idx:1386,width:12,title:'VLC'};
"SubType" : "X10",
"SwitchType" : "Media Player",
"SwitchTypeVal" : 17,
"Timers" : "false",
"Type" : "Lighting 1",
"TypeImg" : "Media",
Posted: Saturday 26 April 2025 12:47
by Lokonli
madpatrick wrote: Saturday 26 April 2025 11:34
I will make styling a bit easier.
Can you add the following to custom.css for testing:
.mh {
--col1width: 30px;
--col2width: 30px;
.right2col {
padding-right: calc(var(--col1width) + var(--col2width) + 8px);
.col-button2 {
width: calc(var(--col1width) + var(--col2width));
.col-button2 .btn-number {
width: var(--col1width);
.btn.stop {
width: var(--col2width);
font-size:20px;
display: flex;
justify-content: center;
align-items: center;
/*Only change below this line*/
.mh {
--col1width: 60px;
--col2width: 60px;
.mh .btn {
background-color: #00aaff;
border-radius: 5px;
.mh .btn.stop {
background-color: red;
You can change the width of the up/down and stop button via the two parameters: now they are 60px.
The styling can be done via ".mh .btn", or via ".mh .btn.stop" for the stop button only.
If this is working for you let me know, and I'll include in the next version.
