How to get device back in Dashboard/Others
Posted: Tuesday 25 March 2025 18:34
Version: 2024.7
Platform: openSUSE Leap 15.5
Plugin/Hardware: PlugwiseStretch
Description: PlugwiseStretch reads production of Solarpanels but does not appear in Others and Dashboard
System/plugin works since 2021-01-01, only after a certain update of the system and/or domoticz this plugin lost its some of its configuration data and did not collect its data anymore. I saved content of the table meter_calendar. After that I removed the entries of the devices and the hardware. Also cleaned the directory with the plugin, only leaving the file plugin.py.
Next I selected again the hardware, entered the necessary parameters and the hardware and the two devices appeared again in the system. I also see that the table meter gets filled each 5 minutes. Also in the page with the Devices these two devices are present. In this page I changed the green icon with the arrow to the right into a blue icon with the arrow to the left. This should make the device to appear in the tab Others, however it does not. So I can also not make the device to appear in the Dashboard.
How do I get this device to appear in Others/Dashboard?
