Version: 2024.7
Platform: openSUSE Leap 15.5
Plugin/Hardware: PlugwiseStretch
Description: PlugwiseStretch reads production of Solarpanels but does not appear in Others and Dashboard
System/plugin works since 2021-01-01, only after a certain update of the system and/or domoticz this plugin lost its some of its configuration data and did not collect its data anymore. I saved content of the table meter_calendar. After that I removed the entries of the devices and the hardware. Also cleaned the directory with the plugin, only leaving the file plugin.py.
Next I selected again the hardware, entered the necessary parameters and the hardware and the two devices appeared again in the system. I also see that the table meter gets filled each 5 minutes. Also in the page with the Devices these two devices are present. In this page I changed the green icon with the arrow to the right into a blue icon with the arrow to the left. This should make the device to appear in the tab Others, however it does not. So I can also not make the device to appear in the Dashboard.
How do I get this device to appear in Others/Dashboard?
How to get device back in Dashboard/Others
Forum rules
Version: xxxx
Platform: xxxx
Plugin/Hardware: xxxx
Description:
Version: xxxx
Platform: xxxx
Description:
- Domoticz version: 2025.1
Re: How to get device back in Dashboard/Others
Check the device assignments in menu Setup - Users.
If you have only 1 user account (and admin) that assignment list should be empty. Also for an admin this device assignment list should be empty. You normally only assign devices to other users accounts (also for device sharing)
See also the notes on this subject in the wiki https://wiki.domoticz.com/User_Management#Set_Devices
freekdk
- Domoticz version: V2025.1
Thanks!! That did the trick.
