how to use notifications
BartSr
Domoticz version: V2024.7
Post by BartSr »
Pushsafer is my app to send pushmessages to inform me about 'a status'.
I am facing next problem.
The availability of voltage on an endcircuit is monitored by a relay. If the circuit breaker of that end-circuit trips the relay goes to 'off'
The on/off signal is interfaced using an esp and published using MQTT to Domoticz.
This status is sent every 10 seconds for test and can later be set to longer time.
In domoticz the status is shown as an on/off device. Both On and Off positions are pushed to my phone by pushsafer.
As a matter of facts every (domoticz receives regular updates from esp) 10 seconds the status is pushed by pushsafer to my phone even if the status has not been changed.
Question: How can I prevent from pushing every 10 seconds same status. I profer to receive only a pushmessage once the status has changed.
Hopefully my problem is described well to understand.
-Bart
ps: the notification settings of device show up most right 'recover'. Can't find meaning. Any idea?
Raspberry pi 3b
Arduino
KAKU
RfxCom
Zwave2MQTT
OTGW
Tasmota
Esp8266 / 32 espeasy
Zigbee2MQTT
HvdW
Domoticz version: 2023.2
Re: how to use notifications
Post by HvdW »
BartSr wrote: Wednesday 12 March 2025 21:28 As a matter of facts every (domoticz receives regular updates from esp) 10 seconds the status is pushed by pushsafer to my phone even if the status has not been changed.
It's the updates that trigger.
You might write a small script to trigger the notifications.
It triggers on any change of state of mySwitch and inside the script it decides wheter it was switched from Off to On.
        devices = { 'mySwitch' } -- Replace 'mySwitch' with the name of your switch
    data = {
        prevState = { initial = 'Off' } -- This stores the previous state of the switch
        -- Check if the state has changed from 'Off' to 'On'
        if device.state == 'On' and domoticz.data.prevState == 'Off' then
            -- Send a notification
            domoticz.notify('Switch turned on', 'mySwitch has just been turned on', domoticz.PRIORITY_NORMAL)
        -- Update the previous state
        domoticz.data.prevState = device.state
Bugs bug me.
BartSr
Post by BartSr »
Thanks very much for your help. I am using dzVents for simple scripts where I never used the data{} strophe. So have to read the docu about this.
I didnot mention that in fact I have three of these monitors.
Can you tell me how to update your script for 3 devices?
Bart
Raspberry pi 3b
Arduino
KAKU
RfxCom
Zwave2MQTT
OTGW
Tasmota
Zigbee2MQTT
HvdW
Post by HvdW »
        devices = { 'mySwitch1', 'mySwitch2', 'mySwitch3' } -- Add your switch names here
    data = {
        prevState = { initial = { mySwitch1 = 'Off', mySwitch2 = 'Off', mySwitch3 = 'Off' } } -- Initial states for all switches
        -- Check if the state has changed from 'Off' to 'On' for the specific device
        if device.state == 'On' and domoticz.data.prevState[device.name] == 'Off' then
            -- Send a notification for the specific switch
            domoticz.notify('Switch turned on', device.name .. ' has just been turned on', domoticz.PRIORITY_NORMAL)
        -- Update the previous state for the specific device
        domoticz.data.prevState[device.name] = device.state
Bugs bug me.
BartSr
Post by BartSr »
Thanks again! This handles notifcation from 'off to on'.
Do I need two scripts once I also like notification for 'on to off'?
Raspberry pi 3b
Arduino
KAKU
RfxCom
Zwave2MQTT
OTGW
Tasmota
Zigbee2MQTT
HvdW
Post by HvdW »
Try to understand the code and see how easy it is to change it to what you are asking.
You can have it with 6 different messages as well.
Tip:
Before changing code, save the running code as myScript - 1, copy the complete code and past it into a new script myScript - 2 and so on.
Whatever mess you make, you can always return to a running copy.
Bugs bug me.
BartSr
Post by BartSr »
I'll dig in into it and will report back my findings.
Anyway, I m very happy with yr help so far.
-Bart
Raspberry pi 3b
Arduino
KAKU
RfxCom
Zwave2MQTT
OTGW
Tasmota
Zigbee2MQTT
HvdW
Post by HvdW »
This script doesn't use notifications. You can see the results in the log.
2025-03-13 22:11:04.712 Dummy: Light/Switch (mySwitch1)
2025-03-13 22:11:04.798 dzVents: Handling events for: "mySwitch1", value: "On"
2025-03-13 22:11:04.798 dzVents: ------ Start internal script: Script #1: Device: "mySwitch1 (Dummy)", Index: 599
2025-03-13 22:11:04.799 dzVents: Switch turned on. mySwitch1 has just been turned on
2025-03-13 22:11:04.801 dzVents: ------ Finished Script #1
2025-03-13 22:11:16.473 Status: User: admin (IP: 192.168.2.111) initiated a switch command (599/mySwitch1/Off)
2025-03-13 22:11:16.486 Dummy: Light/Switch (mySwitch1)
2025-03-13 22:11:16.636 dzVents: Handling events for: "mySwitch1", value: "Off"
2025-03-13 22:11:16.637 dzVents: ------ Start internal script: Script #1: Device: "mySwitch1 (Dummy)", Index: 599
2025-03-13 22:11:16.638 dzVents: Switch turned off. mySwitch1 has just been turned off
2025-03-13 22:11:16.640 dzVents: ------ Finished Script #1
Above the output using the script below.
        devices = { 'mySwitch1', 'mySwitch2', 'mySwitch3' } -- Voeg hier je schakelaars toe
    data = {
        prevState = { initial = { mySwitch1 = 'Off', mySwitch2 = 'Off', mySwitch3 = 'Off' } } -- Beginstatussen van alle schakelaars
        -- Check of de status is veranderd van 'Off' naar 'On'
            -- Stuur een notificatie voor de specifieke schakelaar
            domoticz.log('Switch turned on. '.. device.name .. ' has just been turned on', domoticz.LOG_INFO)
        -- Check of de status is veranderd van 'On' naar 'Off'
        if device.state == 'Off' and domoticz.data.prevState[device.name] == 'On' then
            domoticz.log('Switch turned off. '.. device.name .. ' has just been turned off', domoticz.LOG_INFO)
        -- Update de vorige status voor de specifieke schakelaar
If you want to make your family and friends go crazy, then go ahead and send notifications for everything changing in your Domoticz setup.
Bugs bug me.
BartSr
Post by BartSr »
This is the updated script. I tested as far as possible but I think it does what is expected.
What is it used for? This domoticz application is installed in a scouting building.
Since the building has been used (newbuilt ) we face now and then a trip of 'groep 13'.
As there is not always anybody in the building it might take time to discover that failure.
If the failure happened then it's good to get an alert. Meanwhile, as I'm on distance, I'm happy to see someone fixed the power failure.
Another thing to monitor is the power supply towards an UPS which in turn supplies a local server for among others 'Salto locks'.
Very unlikely if nobody is aware of a coming power failure. (Once someone unplugged the UPS as he needed a socket outlet..... yes dumb, but it happened.
Then we once faced trip of a CB from feeding grid. That resulted in less pv-panel energy back into the grid so lost money... (there are 72 panels)
Hope this makes sense to you.
        devices = { 'Groep13', 'UPS', 'L1', 'L2', 'L3' } -- Add your switch names here
    data = {
        prevState = { initial = { Groep13 = 'Off', UPS = 'Off', L1 = 'Off', L2 = 'Off', L3 = 'Off' } } -- Initial states for all switches
            domoticz.notify('Power Failure', device.name .. ' is getript', domoticz.PRIORITY_NORMAL)
        elseif
            domoticz.notify('Power failure solved', device.name .. ' is hersteld', domoticz.PRIORITY_NORMAL)
Raspberry pi 3b
Arduino
KAKU
RfxCom
Zwave2MQTT
OTGW
Tasmota
Zigbee2MQTT
BartSr
Post by BartSr »
@ HvdW
So far the script does what's desired.
It's in use for almost two weeks now and then next Q rises:
On board vessels we had an alarmsystem with possibility to delay incoming alarms e.g. for tanklevels (due to vessels movements).
Is such a delay doable to get a more 'quit' system (preventing from false alarms) ?
-Bart
Raspberry pi 3b
Arduino
KAKU
RfxCom
Zwave2MQTT
OTGW
Tasmota
Zigbee2MQTT
Domoticz version: 2025.1
BartSr wrote: Monday 24 March 2025 15:35 @ HvdW
-Bart
That should be in the not shown logic here that sets the state of the devices 'Groep13', 'UPS', 'L1', 'L2', 'L3'
How do you decide when eg L1 is OFF, if Current L1=0 A?
Then you could add in that script that current L1 should be 0 for X seconds or minutes.
You can store the value in persistent data.
See for an example this discussion: viewtopic.php?t=43024
HvdW
Post by HvdW »
I am using the system alive check from the dzvents examples to get notifications.
-- System-alive-check
-- this script can be used in conjunction with the System-alive checker plug-in.
-- the plugin pings a list of devices and creates switches for these devices
-- the reason for this script is to not treat devices as dead immediately after they
-- do not respond. More often than not, the second ping atempt does work. So only
-- if the device has been not responding for a while AFTER it is been presumed dead
-- then this script will notify you
-- put the names of these switches in the devicesToCheck list
-- you may have to tweak the THRESHOLD depending on the check interval
local THRESHOLD = 10 -- minutes
local devicesToCheck =
            'Power', 'Gas', -- 'Luftdaten',
return
    on =
        devices = devicesToCheck,
        timer =
            'every 6 minutes',
    data =
        notified = { initial = {} },
    logging =
        level = domoticz.LOG_ERROR, -- change from LOG_DEBUG to LOG_ERROR when script executes without problems
        marker = 'notify',
    execute = function(dz, item)
        if item.isTimer then
            for index, deviceName in ipairs(devicesToCheck) do
                local device = dz.devices(deviceName)
                dz.log('device name  ' .. device.name, dz.LOG_DEBUG)
                dz.log('device state ' .. device.state, dz.LOG_DEBUG)
                dz.log('device lastUpdate ' .. device.lastUpdate.minutesAgo, dz.LOG_DEBUG)
                dz.log('device notified ' .. tostring(dz.data.notified[deviceName]), dz.LOG_DEBUG)
                if device.lastUpdate.minutesAgo >= THRESHOLD and dz.data.notified[deviceName] ~= true  then
                    -- verwijderd bij de if statement device.state == 'Off' and
                    dz.log('Idle device ' .. deviceName, dz.LOG_DEBUG)
                    dz.notify('notifyer', deviceName .. ' is not responding anymore.',dz.PRIORITY_HIGH)
                    dz.data.notified[deviceName] = true   -- om deze regel, daar draait het om -> eenmalige notificatie
            dz.data.notified[item.name] = false
--einde system alive check
Thank you dzVents developers for your great work.
I always fail to find the recent examples, here are some older ones.
Bugs bug me.
BartSr
Post by BartSr »
@Waltervl
There are relays supplied by power circuits to monitor.
The relay change-over contact controls input of esp which in turn controls the domoticz device via MQTT so no Amp value. Also using Amp value might be not always reliable in case of no consumers in use.
Raspberry pi 3b
Arduino
KAKU
RfxCom
Zwave2MQTT
OTGW
Tasmota
Zigbee2MQTT
So how can these relay devices give a false result?
BartSr
Post by BartSr »
@waltervl
If relay has been energized power is there.
If power fails relay is deenergized
Raspberry pi 3b
Arduino
KAKU
RfxCom
Zwave2MQTT
OTGW
Tasmota
Zigbee2MQTT
BartSr
Post by BartSr »
@HvdW
Thanks for the example. I had a quick view. Do I understand it notifies in case of a failure but not once the failure is solved?
Great link to all examples! I've never been aware of this treasure ;)
Raspberry pi 3b
Arduino
KAKU
RfxCom
Zwave2MQTT
OTGW
Tasmota
Zigbee2MQTT
BartSr wrote: Tuesday 25 March 2025 20:48 @waltervl
So how can this create false alarms? If no false alarms no need to change the script.
And if the value is always true you do not even need a script but use the standard notifications functionality on the switch.
Edit: reading back the topic you should not have the esp send every x seconds an update to MQTT but only when the status has changed.....
BartSr
Post by BartSr »
Walter, all you say is true. But if the wifi is not that stable misinformation might be there once a single event would fire a notification. And yes, the wifi in the building is not reliable.
Raspberry pi 3b
Arduino
KAKU
RfxCom
Zwave2MQTT
OTGW
Tasmota
Zigbee2MQTT
If wifi is not reliable you also wont get the notification if there is a true situation.
You could also have the esp check if the MQTT message is received in mosquitto. If not (due to wifi issues) resend the message. Check the esp mqtt library how to do that as it should be a normal functionality.
