init persistent data with value
pierrotori
Domoticz version: 2024.4
Post by pierrotori »
i have this
data = {
	value= { history = true, maxItems = 12}
And to init
-- init the persistent data  to zero
for i=1,12 do
	dz.data.value.add(0)
is it the best solution to init the persistent data ?
Pierrotori
Last edited by pierrotori on Wednesday 12 March 2025 8:20, edited 1 time in total.
rpi : Raspberry Pi 2 Model B Rev 1.1 / Modele : Cortex-A7 armv7l GNU/Linux / Os Name : bullseye
Docker/Domoticz/zwave-ui/homebridge/mosquitto/wireguard
Domoticz version: 2025.1
Re: init persistent data with value
Why do you need to initialize the data?
Normally you just let if fill and do the math afterwards. Do you get errors?
You also define a persistent data table named value but you add data to a table named mesure. Could be a typing error due to copy/paste but you better not use it into one script... :)
pierrotori
i initialize the data, because the data will be insert every 5 minutes, it's take 60 minutes to have all the mesure and i have a function that calculate the standard deviation with the all values
i used the parameter size or check if the data is not equal to nil, but in my case it's more easy to add zero when the script start , because the value zero is the value for no consumption water for the last hour
in fact it's a error for the table name, i updated
