How to put result of calculation into mqtt command
sailmich
Post by sailmich »
I'm using node red to regulate fan speed I installed under my water heaters. It's running well. Till now I regulate the fan speed in steps e.g. 30/40/50%. I would like to do this with calculation in relation to the input temperature. E.g. 30°C => 40% fan speed and 35°C => 60% fan speed.
My problem is how can I get the calculated result into the function node to sent it to the fan.
        "id": "cf3ed0c4e266eb23",
        "type": "change",
        "z": "27bd8ea24b66cf31",
        "name": "calculate consumption",
        "rules": [
                "t": "set",
                "p": "payload",
                "pt": "msg",
                "to": "payload*4-80",
                "tot": "jsonata"
        "action": "",
        "property": "",
        "from": "",
        "to": "",
        "reg": false,
        "x": 1600,
        "y": 840,
        "wires": [
                "864087b683e6aecc",
                "f60883853089911c"
        "id": "dee39cb0daa74649",
        "type": "function",
        "name": "SZ_40%",
        "func": "msg.topic = \"cmnd/tasmota_07235490/DIMMER\";\nmsg.payload = \"40\";\nreturn msg;\n",
        "outputs": 1,
        "timeout": "",
        "noerr": 0,
        "initialize": "",
        "finalize": "",
        "libs": [],
        "x": 1640,
        "y": 760,
        "wires": [
                "29a2b83b8fe6679b"
        "id": "b685926d288f295d",
        "type": "inject",
        "name": "",
        "props": [
                "p": "payload"
                "p": "topic",
                "vt": "str"
        "repeat": "",
        "crontab": "",
        "once": false,
        "onceDelay": 0.1,
        "topic": "SZ_Vorlauf",
        "payload": "35",
        "payloadType": "num",
        "x": 1390,
        "y": 840,
        "wires": [
                "cf3ed0c4e266eb23",
                "dee39cb0daa74649",
                "08a697749e95080c"
        "id": "08a697749e95080c",
        "type": "debug",
        "name": "debug 1",
        "active": true,
        "tosidebar": true,
        "console": false,
        "tostatus": false,
        "complete": "false",
        "statusVal": "",
        "statusType": "auto",
        "x": 1580,
        "y": 900,
        "wires": []
        "id": "1ba62f886d0ad6f5",
        "type": "function",
        "name": "SZ_Variable%",
        "func": "msg.topic = \"cmnd/tasmota_07235490/DIMMER\";\nmsg.payload = msg.payload.payload;\nreturn msg;\n",
        "outputs": 1,
        "timeout": "",
        "noerr": 0,
        "initialize": "",
        "finalize": "",
        "libs": [],
        "x": 1940,
        "y": 840,
        "wires": [
                "7ccc2104d4956d9a"
        "id": "29a2b83b8fe6679b",
        "type": "debug",
        "name": "debug 2",
        "active": true,
        "tosidebar": true,
        "console": false,
        "tostatus": false,
        "statusVal": "",
        "x": 1800,
        "y": 760,
        "wires": []
        "id": "b66ecb5d3146f17a",
        "type": "comment",
        "name": "working",
        "info": "",
        "x": 1630,
        "y": 720,
        "wires": []
        "id": "bb672a74f1f6887a",
        "type": "comment",
        "name": "need help",
        "info": "",
        "x": 1920,
        "y": 800,
        "wires": []
        "id": "f60883853089911c",
        "type": "debug",
        "name": "debug 3",
        "active": true,
        "tosidebar": true,
        "console": false,
        "tostatus": false,
        "statusVal": "",
        "x": 1780,
        "y": 900,
        "wires": []
        "id": "864087b683e6aecc",
        "type": "json",
        "name": "",
        "property": "payload",
        "action": "",
        "pretty": false,
        "x": 1790,
        "y": 840,
        "wires": [
                "1ba62f886d0ad6f5"
        "id": "7ccc2104d4956d9a",
        "type": "debug",
        "name": "debug 4",
        "active": true,
        "tosidebar": true,
        "console": false,
        "tostatus": false,
        "statusVal": "",
        "x": 2120,
        "y": 840,
        "wires": []
FireWizard
Re: How to put result of calculation into mqtt command
Post by FireWizard »
Hi @sailmich,
Question
Where do you do that calculation?
Is it a separate program, that gives you a result on the command line.
Is it on the same computer/Raspberry Pi, which runs Node-RED
Or is it done in Node-RED itself? If so, can you post the flow?
sailmich
Post by sailmich »
Hello FireWizard,
a sample of the flow is in my first post. I got the temperature from a Shelly addon with node mqtt in. Than I'm doing the calculation within a change node. I would like to sent it with mqtt to a Shelly.
Cheers
FireWizard
Hi, @sailmich,
Actually this has no relationship with Domoticz.
You receive the temperature from a Shelly addon in Node-Red by MQTT input node. You do the calculation in a Change node.
The result you want to send to a MQTT output node to a Shelly device.
Which Shelly device? A Gen 1 or Gen 2/3 device.
Type number?
Is de input addon connected to the same device as you want to control?
FireWizard
Hi, @sailmich,
I loaded your flow in my test system with Node RED.
Honestly said, I do not understand what you really want to achieve.
Let me explain.
You "Inject" a numerical value (35). I assume that this shall represent the temperature, so 35°C.
This has a topic, called "SZ_Vorlauf", which I think means "Forward".
You send this to a "Function" node as follows:
msg.topic = "cmnd/tasmota_07235490/DIMMER";
msg.payload = "40";
return msg;
The result is "40". I understand this, as probably most readers will do.
It will always be "40". But why the topic with DIMMER?
You added a comment, "Working". Okay, I understand.
Now the lower stream.
You "Inject" 35. and send that to a "Change" node and with a JSONata expressions ((35 x 4) -80) = (140 -80).
This results in a numerical value 60. It does not surprise me.
You put this value of 60 in a JSON node and the output is ...."60". I understand this.
Then you put this in a "Function" node with the following contents:
return msg;
Again the Dimmer topic
Your incoming payload = "60", but you send to the output msg.payload.payload, which does not exist,
So your "Debug" node shows "undefined".
Where, do you need help for?
I really do not understand what kind of help you expect to receive, because I do not see any relationship between tasmota, Dimmer, temperature and controlling a Shelly.
Explain please, what you want, what your input is and what you expect as output.
sailmich
Post by sailmich »
@FireWizard,
sorry for confusing you!
I shouldn't put the code inside the post as I did.
[Again the Dimmer topic
You gave me the right kick instead of msg.payload.payload I should use msg.payload. With that the flow is working as I want!
Thank you very much!
        "type": "change",
        "rules": [
                "t": "set",
                "p": "payload",
                "pt": "msg",
                "tot": "jsonata"
        "action": "",
        "property": "",
        "from": "",
        "to": "",
        "reg": false,
        "x": 1600,
        "y": 840,
        "wires": [
                "864087b683e6aecc"
        "type": "inject",
        "name": "",
        "props": [
                "p": "payload"
                "p": "topic",
                "vt": "str"
        "repeat": "",
        "crontab": "",
        "once": false,
        "onceDelay": 0.1,
        "payload": "35",
        "x": 1390,
        "y": 840,
        "wires": [
                "cf3ed0c4e266eb23"
        "type": "function",
        "func": "msg.topic = \"cmnd/tasmota_07235490/DIMMER\";\nmsg.payload = msg.payload;\nreturn msg;\n",
        "outputs": 1,
        "timeout": "",
        "noerr": 0,
        "initialize": "",
        "finalize": "",
        "libs": [],
        "x": 1940,
        "y": 840,
        "wires": [
                "957df9569f0dc0df"
        "type": "json",
        "name": "",
        "action": "",
        "pretty": false,
        "x": 1790,
        "y": 840,
        "wires": [
                "1ba62f886d0ad6f5"
        "id": "957df9569f0dc0df",
        "type": "mqtt out",
        "name": "To WLAN Thermostat",
        "topic": "",
        "qos": "",
        "retain": "",
        "respTopic": "",
        "contentType": "",
        "userProps": "",
        "correl": "",
        "expiry": "",
        "broker": "f9f13036.e28b58",
        "x": 2180,
        "y": 840,
        "wires": []
        "id": "f9f13036.e28b58",
        "type": "mqtt-broker",
        "name": "Homeserver",
        "broker": "192.168.178.91",
        "port": "1883",
        "clientid": "",
        "autoConnect": true,
        "usetls": false,
        "protocolVersion": "4",
        "keepalive": "60",
        "cleansession": true,
        "autoUnsubscribe": true,
        "birthTopic": "",
        "birthQos": "0",
        "birthRetain": "false",
        "birthPayload": "",
        "birthMsg": {},
        "closeTopic": "",
        "closeQos": "0",
        "closePayload": "",
        "closeMsg": {},
        "willTopic": "",
        "willQos": "0",
        "willPayload": "",
        "willMsg": {},
        "userProps": "",
        "sessionExpiry": ""
FireWizard
Hello @sailmich,
If you are happy, I have to be as well :D .
