Sonoff SWV
jacobsentertainment
Domoticz version: 2021-1
Sonoff SWV
Post by jacobsentertainment »
I have bought an Sonoff SWV and paired it with ZigbeeForDomoticz, it pops up without any issues, in devices two appear an voltage and a switch.
On using the swith I get a error in my log that I dont understand. Maybe the device is not fully implemented yet but wanted to share it here.
 2025-03-05 12:24:55.791 zigbee: UpdateDevice - (zigbee - SWV_Voltage-28dba7fffe6d0ba5-01) 0:200.0;200.0
2025-03-05 12:24:55.821 zigbee: UpdateDevice - (zigbee - SWV_Voltage-28dba7fffe6d0ba5-01) 0:6.4;6.4
2025-03-05 12:24:55.829 zigbee: UpdateDevice - (zigbee - SWV_Voltage-28dba7fffe6d0ba5-01) 0:200.0;200.0
2025-03-05 12:24:59.138 Status: User: Olaf (IP: 192.168.178.120) initiated a switch command (801/zigbee - SWV_Switch-28dba7fffe6d0ba5-01/On)
2025-03-05 12:24:59.154 zigbee: UpdateDevice - (zigbee - SWV_Switch-28dba7fffe6d0ba5-01) 1:On
2025-03-05 12:24:59.812 Error: zigbee: ReadCluster - Warning - unknow 0250/01 Cluster: fc11 Attribute: 5006 Status: 00 DataType: 23 DataSize: 0004 Data: 00000000
2025-03-05 12:24:59.820 Error: zigbee: ReadCluster - Warning - unknow 0250/01 Cluster: fc11 Attribute: 5007 Status: 00 DataType: 23 DataSize: 0004 Data: 00000000
2025-03-05 12:24:59.832 Error: zigbee: ReadCluster - Warning - unknow 0250/01 Cluster: fc11 Attribute: 500d Status: 00 DataType: 23 DataSize: 0004 Data: 00000000
2025-03-05 12:24:59.843 Error: zigbee: ReadCluster - Warning - unknow 0250/01 Cluster: fc11 Attribute: 500e Status: 00 DataType: 23 DataSize: 0004 Data: 00000000
2025-03-05 12:25:01.449 Status: User: Olaf (IP: 192.168.178.120) initiated a switch command (801/zigbee - SWV_Switch-28dba7fffe6d0ba5-01/Off)
2025-03-05 12:25:01.469 zigbee: UpdateDevice - (zigbee - SWV_Switch-28dba7fffe6d0ba5-01) 0:Off
2025-03-05 12:25:01.805 Error: zigbee: ReadCluster - Warning - unknow 0250/01 Cluster: fc11 Attribute: 500f Status: 00 DataType: 23 DataSize: 0004 Data: 00000000
2025-03-05 12:25:01.827 Error: zigbee: ReadCluster - Warning - unknow 0250/01 Cluster: fc11 Attribute: 5010 Status: 00 DataType: 20 DataSize: 0001 Data: 00
2025-03-05 12:25:01.847 Error: zigbee: ReadCluster - Warning - unknow 0250/01 Cluster: fc11 Attribute: 500c Status: 00 DataType: 20 DataSize: 0001 Data: 00
2025-03-05 12:25:14.923 zigbee: UpdateDevice - (zigbee - SWV_Switch-28dba7fffe6d0ba5-01) 1:On
2025-03-05 12:25:14.935 Error: zigbee: ReadCluster - Warning - unknow 0250/01 Cluster: fc11 Attribute: 500d Status: 00 DataType: 23 DataSize: 0004 Data: 2f5aff28
2025-03-05 12:25:15.393 Error: zigbee: ReadCluster - Warning - unknow 0250/01 Cluster: fc11 Attribute: 500e Status: 00 DataType: 23 DataSize: 0004 Data: 2f5aff28
2025-03-05 12:25:15.920 zigbee: UpdateDevice - (zigbee - SWV_Switch-28dba7fffe6d0ba5-01) 0:Off
The lines with on/off is my switching the device.
Domoticz version: 2025.1
Re: Sonoff SWV
Check the Z4D user interface and see if the device is reported as certified in menu Management - Devices.
If the device is not certified it has a different Icon in the beginning of the list. You can report than that device to the repository: https://github.com/zigbeefordomoticz/z4 ... e-model.md
Are you on the latest version of the plugin? Also check this in the user interface https://zigbeefordomoticz.github.io/wik ... ation.html
jacobsentertainment
Re: Sonoff SWV
Thanks again Waltervl :D
