how use idx iso names
BartSr
Domoticz version: V2024.7
Post by BartSr »
this an example from the wiki
return
on =
devices = {
'myDetector',
'roomTemp'
if ((device.name == 'myDetector' and device.active) or
(device.name == 'roomTemp' and device.temperature >= 45)) then
domoticz.notify('Fire', 'The room is on fire', domoticz.PRIORITY_EMERGENCY)
I am looking for a way to use IDX iso names as imho this is better to maintain once names should change
I think it's not that difficult but can't find the syntax
Raspberry pi 3b
Arduino
KAKU
RfxCom
Zwave2MQTT
OTGW
Tasmota
Esp8266 / 32 espeasy
Zigbee2MQTT
Domoticz version: 2025.1
Re: how use idx iso names
Just replace names with the appropriate IDX.
And instead of
If device.name == 'myDevice'
use
If device.idx == 1234
BartSr
Post by BartSr »
I just learned using names is more stable so I keep it with names.
Raspberry pi 3b
Arduino
KAKU
RfxCom
Zwave2MQTT
OTGW
Tasmota
Zigbee2MQTT
No, names should be unique. So when changing names they still should be unique.
I am used to using IDX in my dzvents script so when I change a name I do not need to care about my scripts. I only need to take care my names are unique (but that is in every use case an obligation)
HvdW
Domoticz version: 2023.2
Post by HvdW »
A tip: When using dzVents scripts and devices I edit the devices involved and write the name of the script in the description to be able to find out where between all scripts this device is updated.
Bugs bug me.
BartSr
Post by BartSr »
Thanks. Good Tip!
Raspberry pi 3b
Arduino
KAKU
RfxCom
Zwave2MQTT
OTGW
Tasmota
Zigbee2MQTT
