Hoog gasverbruik
Posted: Tuesday 11 February 2025 5:57
by edwin1234
Ik heb opeens een enorm hoog gasverbruik tenminste dat geeft hij aan. In het log allemaal errors dat hij een verkeerde waarde heeft ontvangen.
Wat kan hier de oorzaak van zijn? en is de waarde te verwijderen?
Ik gebruik een sensor op de gasmeter met rfxcom.
Re: Hoog gasverbruik
Posted: Tuesday 11 February 2025 8:49
by jannl
Ik heb ook wel eens een foute meting. Met linker-shift en linker muisknop op die waarde kun je hem verwijderen
Posted: Tuesday 11 February 2025 13:12
Please use English language!!!
To remove the value use Shift+click on the value in the graph. You will get a popup to delete the value.
And check your rfxcom devices if this incorrect values are coming back.
Posted: Tuesday 11 February 2025 13:36
by edwin1234
Sorry I forgot the English part
Thank you both for your answer.
Posted: Monday 24 March 2025 6:16
by edwin1234
I did reset the high values
But almost once a week the rfxgas values
Are high and then the next day normal again.
Any ideas?
Posted: Monday 24 March 2025 8:56
Some ideas: Optimize your RF network so it wont send bad data once a week. Could also be some other device is interrupting the signal.
Posted: Monday 24 March 2025 10:19
by gizmocuz
Another option is to use a P1 USB cable?
Posted: Monday 24 March 2025 19:50
by edwin1234
I dont have a smart meter and dont want one
Posted: Monday 24 March 2025 21:10
edwin1234 wrote: Monday 24 March 2025 19:50
That is going to be solved for you in a couple of years....
But on topic:
Is there a more reliable (wired/wifi/zigbee) way to get the data into Domoticz? What kind of energy meter do you have?
Posted: Tuesday 25 March 2025 6:00
by edwin1234
I have a “draaistroommeter” a disk dat spins to the right or left when or not there is sun.
I have a rfxsensor wired to a rfxmeter on it from rfxcom for many many years and never had this high spikes before.
Posted: Tuesday 25 March 2025 8:36
by gizmocuz
Please make sure you do not have any RF interference , maybe a faulty temperature sensor (I had this year ago)
Maybe clean the sensor? Attach it again? Upgrade the RFXCom firmware, disable protocols you don't use
Posted: Tuesday 25 March 2025 11:05
by edwin1234
Thanks for your answer,
I will try that, i hope it helps.
