Does anyone know how to connect a water pressure sensor (in the heating system) to Domoticz?
There is an i2c sensor xdb401. (There is a datasheet from the manufacturer for it).
As a last resort - an analog one with an output of 0-5 volts, for example.
How to connect a water pressure sensor (in a heating system) in Domoticz?
vladimirk68
- Domoticz version: 2025.1
Re: How to connect a water pressure sensor (in a heating system) in Domoticz?
Check the https://esphome.io/ project where you can connect sensors to all kind of cheap wifi microcontrollers and have the data sent to Domoticz over MQTT Autodiscover protocol
https://esphome.io/components/mqtt.html ... t-entities
Domoticz MQTT Autodiscover:
https://wiki.domoticz.com/MQTT#Add_hard ... Gateway%22
- habahabahaba
- Domoticz version: 2024.4
Answered you in 4pda
Got one working. Any questions - welcome
