chrome STATUS_ACCESS_VIOLATION
Forum rules
Version: xxxx
Platform: xxxx
Plugin/Hardware: xxxx
Description:
rfvdboom
Domoticz version: 2023.2
Post by rfvdboom »
since a few days i cant access the dashboard in Chrome. The browser loads for a couple of seconds and then: STATUS_ACCESS_VIOLATION.
I dont says this is a Domoticz issue, because is you google this error it happend often.
But it i have this issue only on my raspberry with Domoticz. My tohersservice like Zwave JS Ui en Pihole are accessable (running on the same device, so same IP). When i go the the Domoticz on my Odroid it loads just fire.
Already restart, clear Cache etc. But no luck. At the end my domoticz (raspberry) wont open in Chrome. It is working in MS edge.
Maybe someone has a clue what the problem (and solution) it could be.
thx Grtz
Odroid N2+ | Raspberry P 3 ModelB | RFXcom | AEOTEC Zwave | Honeywell Lyric T6| Milight | Milighthub (NodeMCU) | SolarEdge | P1 Smart meter USB | KAKU | Wemos D1 (esphome) | Denon | Logitech Harmony
Domoticz version: 2024.7
Re: chrome STATUS_ACCESS_VIOLATION
Are using http (eg 8080) or https?
Behind a VPN or firewall?
zicht
Domoticz version: 2023.1+
Post by zicht »
The `STATUS_ACCESS_VIOLATION` error in application generally indicates that the program is trying to access memory that it shouldn't be, which can be caused by various factors, including browser extensions, outdated software, or even hardware issues.
did you try to disable/delete all extentions ?
Are you using the webgui directly or is there a "middle"ware in place where you connect to like proxy or something ?
Is it the same with edge / internet explorer / firefox ?
Did you try from another device ?
Is this occuring since any update on your side ?
Hope these questions help you to find the cullprit ... (it should be something localy on your side ?)
rfvdboom
Post by rfvdboom »
Well after a couple of days not working, it is working again. But dont have any clue what causes the problem and what fixed the problem :?
