Zwave Nodes not showing
wintereyes
Post by wintereyes »
I recently upgrade from 2021-something to 2024.7. In doing so, my zwave nodes disappeared from the Nodes tab ("No data available in table") under Setup > Hardware > my zwave controller > Setup. They are however still present on the tabs Groups and Neighbours, and also present in Setup > Devices . They are all switches and I can turn them off and on, but not having them on the Nodes tab means I can't rename them, Refresh Node info, etc.
What has gone wrong and what can I do to solve this?
Domoticz version: 2024.7
Re: Zwave Nodes not showing
Could be a caching issue. Did you clear your cache or start Domoticz browser session in private/incognito mode?
Also consider moving away from OpenZwave as that project is abandoned and Domoticz is moving to zwave-JS-Ui https://wiki.domoticz.com/Zwave-JS-UI
wintereyes
Thank you. It was indeed a caching issue. I have had caching issues with Domoticz before, but always "all over", so to speak, not just in one place, so I did not suspect it here.
Ok, move away from OpenZwave, sounds reasonable. I will. Might be a spring project, though, when bedroom radiators don't need to be managed...
