Api not working as expected in last beta neither in older version giving two different results
Forum rules
Version: xxxx
Platform: xxxx
Plugin/Hardware: xxxx
Description:
shakimiledy
Post by shakimiledy »
Version: 2024.4 (build 16105)
Platform: PRETTY_NAME="Raspbian GNU/Linux 11 (bullseye)"
NAME="Raspbian GNU/Linux"
VERSION_ID="11"
VERSION="11 (bullseye)"
Version: 2024.4 (build 16105) :
command :
curl -s --insecure 'https://user:[email protected]:443/json.htm?type=devices&rid=306' | jq .result[0].Level | sed 's/[^0-9]//g'
WORKS PERFECTLY BUT GIVEN RTYPE DEPRECATED IN THE LOGS
command :
curl -s --insecure 'https://user:[email protected]:443/json.htm?type=getdevices&rid=306' | jq .result[0].Level | sed 's/[^0-9]//g'
GIVES ERR RESPONSE
LAST DEVELOPMENT BUILD Commit f4f5300
command :
GIVES NOT FOUND ERROR
command :
curl -s --insecure 'https://user:[email protected]:443/json.h ... es&rid=306' | jq .result[0].Level | sed 's/[^0-9]//g' GIVES NOT FOUND ERROR TOO
what can be the issue?
jvdz
Domoticz version: 4.107
Re: Api not working as expected in last beta neither in older version giving two different results
Post by jvdz »
Ignoring an warning doesn't solve it! ;)
The issue is as stated in the reply you have had for quite some time now, which is extensively discussed here before:
viewtopic.php?t=40415&hilit=Rtype
and in the Wiki you will find all details: https://wiki.domoticz.com/Domoticz_API/ ... and_newer)
The latest Beta's don't support the old format anymore, hence it's failing now.
Users browsing this forum: RonkA and 1 guest
