Something stupid , a dummy problem "actualWatt"
Posted: Monday 20 January 2025 15:22
by PeterRozenveld
I keep getting an error in line 21:
" Local kmptt = .... "
Does a Dummy (Watts) have different value names ?
And is it possible to use the IF and THEN statement several times in a row ?
return
on =
devices =
'Kookplaat_F1_(Rechts)',
'Kookplaat_F3_(Links_Flexzone)',
'Tot_Fornuis'
logging =
level = domoticz.LOG_DEBUG,
marker = 'Regulating Afz_350',
execute = function(dz, devices)
local kpmtt = domoticz.devices('Tot_Fornuis') -- Tot_Fornuis is a dummy. But .usage or .actualWatt doesn´t work !
if kpmtt >= 100 and kmptt < 350 then
domoticz.openURL('192.168.2.171/light/0?turn=on&brightness=45')
Re: Something stupid , a dummy problem "actualWatt"
Posted: Monday 20 January 2025 15:41
Check the device type and see what are the available Dzvents properties for that device (dummy or not does not matter):
https://wiki.domoticz.com/DzVents:_next ... ic_devices
Posted: Monday 20 January 2025 15:57
by PeterRozenveld
I tried the following
local kpmtt = domoticz.devices(‘Tot Stove’).Energy
local kpmtt = domoticz.devices(‘To-Stove’).Usage
local kpmtt = domoticz.devices(‘To-Stove’).actualWatt
none of them work....
And the translation in Domoticz from Dummy Hardware to Dutch is quite confusing !
2025-01-20 15:55:44.526 Error: dzVents: Error: (3.1.8) Regulating Afz_350: An error occurred when calling event handler 12_Afzuigkap_Regulated_100-350
2025-01-20 15:55:44.526 Error: dzVents: Error: (3.1.8) Regulating Afz_350: ...nts/generated_scripts/12_Afzuigkap_Regulated_100-350.lua:21: attempt to index a nil value (global 'domoticz')
Posted: Monday 20 January 2025 16:01
Can you post a screenshot of the device widget (it shows the device type) or from the Dummy list tell what you have selected:
https://wiki.domoticz.com/Dummy_for_virtual_Switches
Posted: Monday 20 January 2025 16:54
by boum
first fix the basic error between
and
use either domoticz or dz everywhere but not a mix
then follow the advice and find the type of the device to determine which property to query
Posted: Monday 20 January 2025 17:25
by PeterRozenveld
Ok thx!
Done
It's : Usage, Electricity and the property? is .POWER
but that seems not to work either.
Posted: Monday 20 January 2025 18:10
That is the description. The dzvents options are:
Electric usage
.actualWatt: Number. Current Watt usage.
.WhActual: Number. Current Watt usage. (please use actualWatt)
.updateEnergy(energy): Function. In Watt.
But also make sure you do not mixup domoticz and dz references....
Posted: Monday 20 January 2025 18:18
by habahabahaba
local kpmtt = domoticz.devices(113) --idx of Electric counter
if kpmtt.actualWatt >= 100 and kpmtt.actualWatt < 350 then
domoticz.log('Current electricity usage:', domoticz.LOG_INFO)
domoticz.log(kpmtt.actualWatt .. ' Watt', domoticz.LOG_INFO)
Posted: Monday 20 January 2025 19:21
by PeterRozenveld
sorry doesn´t seem to work.
Posted: Monday 20 January 2025 20:22
PeterRozenveld wrote: Monday 20 January 2025 19:21
This is not the whole script. Please use common dzvents sense here
And telling it does not work does also not help. Tell exactly what is not working...
Posted: Tuesday 21 January 2025 6:21
by habahabahaba
Show the full script and the log
Posted: Tuesday 21 January 2025 13:31
by PeterRozenveld
I will be absent until Friday
