Something stupid , a dummy problem "actualWatt"
PeterRozenveld
Post by PeterRozenveld »
I keep getting an error in line 21:
" Local kmptt = .... "
Does a Dummy (Watts) have different value names ?
And is it possible to use the IF and THEN statement several times in a row ?
return
    on =
        devices =
            'Kookplaat_F1_(Rechts)',
            'Kookplaat_F3_(Links_Flexzone)',
            'Tot_Fornuis'
    logging =
        level = domoticz.LOG_DEBUG,
        marker = 'Regulating Afz_350',
    execute = function(dz, devices)
    local kpmtt = domoticz.devices('Tot_Fornuis')  -- Tot_Fornuis is a dummy. But .usage or .actualWatt doesn´t work !
        if kpmtt >= 100 and kmptt < 350  then
                domoticz.openURL('192.168.2.171/light/0?turn=on&brightness=45')
Domoticz version: 2024.7
Re: Something stupid , a dummy problem "actualWatt"
Check the device type and see what are the available Dzvents properties for that device (dummy or not does not matter): https://wiki.domoticz.com/DzVents:_next ... ic_devices
PeterRozenveld
I tried the following
local kpmtt = domoticz.devices(‘Tot Stove’).Energy
local kpmtt = domoticz.devices(‘To-Stove’).Usage
local kpmtt = domoticz.devices(‘To-Stove’).actualWatt
none of them work....
And the translation in Domoticz from Dummy Hardware to Dutch is quite confusing !
2025-01-20 15:55:44.526 Error: dzVents: Error: (3.1.8) Regulating Afz_350: An error occurred when calling event handler 12_Afzuigkap_Regulated_100-350
2025-01-20 15:55:44.526 Error: dzVents: Error: (3.1.8) Regulating Afz_350: ...nts/generated_scripts/12_Afzuigkap_Regulated_100-350.lua:21: attempt to index a nil value (global 'domoticz')
Can you post a screenshot of the device widget (it shows the device type) or from the Dummy list tell what you have selected: https://wiki.domoticz.com/Dummy_for_virtual_Switches
boum
Domoticz version: 4.10717
Post by boum »
first fix the basic error between
and
use either domoticz or dz everywhere but not a mix
then follow the advice and find the type of the device to determine which property to query
PeterRozenveld
Ok thx!
Done
It's : Usage, Electricity and the property? is .POWER
but that seems not to work either.
That is the description. The dzvents options are:
Electric usage
.actualWatt: Number. Current Watt usage.
.WhActual: Number. Current Watt usage. (please use actualWatt)
.updateEnergy(energy): Function. In Watt.
But also make sure you do not mixup domoticz and dz references....
habahabahaba
Domoticz version: 2024.4
Post by habahabahaba »
        local kpmtt = domoticz.devices(113) --idx of Electric counter
        if kpmtt.actualWatt >= 100 and kpmtt.actualWatt < 350  then
            domoticz.log('Current electricity usage:', domoticz.LOG_INFO)
            domoticz.log(kpmtt.actualWatt .. ' Watt', domoticz.LOG_INFO)
PeterRozenveld
sorry doesn´t seem to work.
PeterRozenveld wrote: Monday 20 January 2025 19:21 sorry doesn´t seem to work.
This is not the whole script. Please use common dzvents sense here :-)
And telling it does not work does also not help. Tell exactly what is not working...
habahabahaba
Show the full script and the log
PeterRozenveld
I will be absent until Friday
