Must be not difficult! Adding two values??  [Solved]
PeterRozenveld
Post by PeterRozenveld »
It's Sunday and my brain doesn't want anymore:
What I'm doing wrong ?
Adding two values...
return
    on =
        devices =
            'Kookplaat_F1_(Rechts)',
            'Kookplaat_F3_(Links_Flexzone)',
    logging =
        level = domoticz.LOG_DEBUG,
        marker = 'Adding F1 en F2',
    execute = function(dz, devices)
        targetDevice = dz.devices('Tot_Fornuis') -- define as virtual custom sensor
        -- local ph1 = dz.devices.('Kookplaat_F1_(Rechts)')
        local ph1 = dz.devices('Kookplaat_F1_(Rechts)') --  Fase meting L1 Kookplaat Rechts
        local ph2 = dz.devices('Kookplaat_F3_(Links_Flexzone)') -- Fase neting L2 Links_Flexzone
        local sumForn = ph1 + ph2
        dz.log('Sum of phase1 en phase2' .. sumForn, dz.LOG_DEBUG)
        targetDevice.updateCustomSensor(sumForn)
jvdz
Domoticz version: 4.107
Re: Must be not difficult! Adding two values??
Post by jvdz »
What isn't working or what does the output show? Could be they are strings in which case you need to use the
tonumber() function around them to be able to add them up.
You forgot to define the value for ph1 and ph2. If your device is a Watt meter then it should be something like
local ph1 = dz.devices('Kookplaat_F1_(Rechts)').actualWatt
PeterRozenveld
update Usage I think is wrong somewhere!
return
    on =
        devices =
    logging =
        targetDevice = dz.devices('Tot_Fornuis').Usage -- define as virtual custom sensor
        local ph1 = dz.devices('Kookplaat_F1_(Rechts)').actualWatt --  Fase meting L1 Kookplaat Rechts
        local ph2 = dz.devices('Kookplaat_F3_(Links_Flexzone)').actualWatt -- Fase neting L2 Links_Flexzone
        targetDevice.updateUsage(sumForn)
results this:
2025-01-19 21:23:32.787 Error: dzVents: Error: (3.1.8) Adding F1 en F2: An error occurred when calling event handler 11_Afzkap_SUm
2025-01-19 21:23:32.787 Error: dzVents: Error: (3.1.8) Adding F1 en F2: ...ticz/scripts/dzVents/generated_scripts/11_Afzkap_SUm.lua:29: attempt to index a nil value (global 'targetDevice')
I do notice, still have a lot to learn
Peter
Change targetDevice = dz.devices('Tot_Fornuis').Usage
In
But look in the dzvents wiki per device type what variables are available to see what you want to calculate.....
PeterRozenveld
Re: Must be not difficult! Adding two values??  [Solved]
Thanks, and in particular : waltervl for the right and fine support.
Herewith the working code:
Peter Rozenveld.
return
    on =
        devices =
    logging =
        local ph2 = dz.devices('Kookplaat_F3_(Links_Flexzone)').actualWatt -- Fase meting L2 Links_Flexzone
        targetDevice.updateEnergy(sumForn)
