The block turns on the relay between values ​​600 and 1500 and above 2000
Daro1003
Domoticz version: 2023.1
Post by Daro1003 »
Question: How to create a block so that the relay switches between given values, i.e.:
1. L1 greater than 600 and less than 1500 when charging photovoltaics above 2000
2. L2 greater than 600 and less than 1500 when charging photovoltaics above 2000
3. L2 greater than 600 and less than 1500 when charging photovoltaics above 2000
That is, only in the range of 600 - 1500 and above from photovoltaics 2000. So I constructed a block:
willemd
Re: The block turns on the relay between values ​​600 and 1500 and above 2000
Post by willemd »
Your question is not clear. Are L1 and L2 your relays?
Your point 2 and 3 are exactly the same.
The end of your post is missing.
