I have several shelly plugs in Domoticz which function well, however bulbs are not added correctly into Domoticz. The On/Off swichtch does not work, Color switch functions as brightness under Switches and so the possibility of changing the color of the lamp is not available.
I consulted Github https://github.com/enesbcs/Shelly_MQTT to add Shelly devices to Domoticz. (By the way: shellyteacher4domo does not regocnize the devices listed under shellies in MQTT-Explorer). Shelly Bulb Duo is listed under Supported devices, but apparantly it does not work properly in my case.
Is there a solution for adding Shellt bulbs correctly?
Shelly Duo bulbs incorrecly added to Domoticz
HoogendoornJH
- Domoticz version: 12736
- ShellyTeacher.jpg (282.56 KiB) Viewed 6076 times
- MQTT-Explorer.jpg (275.68 KiB) Viewed 6078 times
- Domoticz.jpg (324.56 KiB) Viewed 6078 times
Aeotec Z-wave Gen5, RFXtrx433xl, Philips Hue Bridge, Davies Weather Station, Honeywell HGI/S80, AurAir CO2
