Help needed python gardena smartwater websocket (SLL problem)
Posted: Sunday 12 January 2025 12:12
import websocket
import datetime
from threading import Thread
import time
import sys
import requests
import json
# account specific values
CLIENT_ID = 'xxxxxxxxxx-xxxx-xxxx-xxxx-MYCLIENTID'
CLIENT_SECRET = 'xxxxxxxxxx-xxxx-xxxx-xxxx-MYSECRET'
API_KEY = 'xxxxxxxxxx-xxxx-xxxx-xxxx-MYKEY'
# other constants
AUTHENTICATION_HOST = 'https://api.authentication.husqvarnagroup.dev'
SMART_HOST = 'https://api.smart.gardena.dev'
class Client:
def restart():
import sys
print("argv was",sys.argv)
print("sys.executable was", sys.executable)
print("restart now")
import os
os.execv(sys.executable, ['python'] + sys.argv)
def on_message(self, ws, message):
x = datetime.datetime.now()
ws.messages_count+=1
print("--")
print("msg ", x.strftime("%H:%M:%S") + " " + str(ws.messages_count))
print(message)
sys.stdout.flush()
thisdict = dict(json.loads(message))
if thisdict["type"]=="COMMON" :
message = "bat:" + str(thisdict["attributes"]["batteryLevel"]["value"])
message = message + " lev:" + str(thisdict["attributes"]["rfLinkLevel"]["value"])
message = message + " stat:" + str(thisdict["attributes"]["rfLinkState"]["value"])
if thisdict["type"]=="SENSOR" :
message = "soilHum: " + str(thisdict["attributes"]["soilHumidity"]["value"])
message = message + " soilTemp:" + str(thisdict["attributes"]["soilTemperature"]["value"])
if thisdict["type"]=="VALVE" :
#print("naam " + str(thisdict["attributes"]["name"]["value"]))
message=str(thisdict["attributes"]["activity"]["value"])
def on_error(self, ws, error):
print("error ", x.strftime("%H:%M:%S"))
print(error)
def on_close(self, ws, close_status_code, close_msg):
self.live = False
print("closed ", x.strftime("%H:%M:%S,%f"))
print("### closed ###")
if close_status_code:
print("status code: "+str(close_status_code))
if close_msg:
print("status message: "+str(close_msg))
client.restart
def on_open(self, ws):
print("connected ", x.strftime("%H:%M:%S,%f"))
print("### connected ###")
self.live = True
def run(*args):
while self.live:
time.sleep(1)
Thread(target=run).start()
def format(response):
formatted = [response.url, "%s %s" % (response.status_code, response.reason)]
for k,v in response.headers.items():
formatted.append("%s: %s" % (k, v))
formatted.append("")
formatted.append(r.text)
return "\n".join(formatted)
if __name__ == "__main__":
while True:
try:
payload = {'grant_type': 'client_credentials', 'client_id': CLIENT_ID, 'client_secret': CLIENT_SECRET}
print("Logging into authentication system...")
r = requests.post(f'{AUTHENTICATION_HOST}/v1/oauth2/token', data=payload)
assert r.status_code == 200, format(r)
auth_token = r.json()["access_token"]
#print("\nLogged in auth_token=(%s)" % auth_token)
headers = {
"Content-Type": "application/vnd.api+json",
"x-api-key": API_KEY,
"Authorization": "Bearer " + auth_token
print("\n### get locations ###")
r = requests.get(f'{SMART_HOST}/v1/locations', headers=headers)
assert len(r.json()["data"]) > 0, 'location missing - user has not setup system'
location_id = r.json()["data"][0]["id"]
#print("\nLocationId=(%s)" % location_id)
payload = {
"data": {
"type": "WEBSOCKET",
"attributes": {
"locationId": location_id
"id": "does-not-matter"
print("\ngetting websocket ID...")
r = requests.post(f'{SMART_HOST}/v1/websocket', json=payload, headers=headers)
assert r.status_code == 201, format(r)
print("\nWebsocket ID obtained, connecting...")
response = r.json()
websocket_url = response["data"]["attributes"]["url"]
websocket.enableTrace(True) #True om raw output in display te hebben
client = Client()
ws = websocket.WebSocketApp(
websocket_url,
on_message=client.on_message,
on_error=client.on_error,
on_close=client.on_close)
ws.messages_count = 0 # Create a counter and an empty list to store messages
ws.on_open = client.on_open
ws.run_forever(ping_interval=120, ping_timeout=3)
except Exception as e:
gc.collect()
print("Websocket connection Error : {0}".format(e))
print("Reconnecting websocket after 600 sec")
time.sleep(600)
Now i tried to start implementing, but when testing it i run into an ssl problem.
The response i get :
error 12:10:05
[SSL: CERTIFICATE_VERIFY_FAILED] certificate verify failed: unable to get local issuer certificate (_ssl.c:997)
[SSL: CERTIFICATE_VERIFY_FAILED] certificate verify failed: unable to get local issuer certificate (_ssl.c:997) - goodbye
closed 12:10:05,445888
### closed ###
Maybe one of the domoticz members with python knowledge can help me out ?
Thanks in advance
