Help needed python gardena smartwater websocket (SLL problem) Topic is solved
zicht
Domoticz version: 2023.1+
Post by zicht »
import websocket
import datetime
from threading import Thread
import time
import sys
import requests
import json
# account specific values
CLIENT_ID = 'xxxxxxxxxx-xxxx-xxxx-xxxx-MYCLIENTID'
CLIENT_SECRET = 'xxxxxxxxxx-xxxx-xxxx-xxxx-MYSECRET'
API_KEY = 'xxxxxxxxxx-xxxx-xxxx-xxxx-MYKEY'
# other constants
AUTHENTICATION_HOST = 'https://api.authentication.husqvarnagroup.dev'
SMART_HOST = 'https://api.smart.gardena.dev'
class Client:
    def restart():
        import sys
        print("argv was",sys.argv)
        print("sys.executable was", sys.executable)
        print("restart now")
        import os
        os.execv(sys.executable, ['python'] + sys.argv)
    def on_message(self, ws, message):
        x = datetime.datetime.now()
        ws.messages_count+=1
        print("--")
        print("msg ", x.strftime("%H:%M:%S") + " " + str(ws.messages_count))
        print(message)
        sys.stdout.flush()
        thisdict = dict(json.loads(message))
        if thisdict["type"]=="COMMON" :
           message = "bat:" + str(thisdict["attributes"]["batteryLevel"]["value"])
           message = message + " lev:" + str(thisdict["attributes"]["rfLinkLevel"]["value"])
           message = message + " stat:" + str(thisdict["attributes"]["rfLinkState"]["value"])
        if thisdict["type"]=="SENSOR" :
           message = "soilHum: " + str(thisdict["attributes"]["soilHumidity"]["value"])
           message = message + " soilTemp:" + str(thisdict["attributes"]["soilTemperature"]["value"])
        if thisdict["type"]=="VALVE" :
           #print("naam " + str(thisdict["attributes"]["name"]["value"]))
           message=str(thisdict["attributes"]["activity"]["value"])
    def on_error(self, ws, error):
        print("error ", x.strftime("%H:%M:%S"))
        print(error)
    def on_close(self, ws, close_status_code, close_msg):
        self.live = False
        print("closed ", x.strftime("%H:%M:%S,%f"))
        print("### closed ###")
        if close_status_code:
            print("status code: "+str(close_status_code))
        if close_msg:
            print("status message: "+str(close_msg))
        client.restart
    def on_open(self, ws):
        print("connected ", x.strftime("%H:%M:%S,%f"))
        print("### connected ###")
        self.live = True
        def run(*args):
            while self.live:
                time.sleep(1)
        Thread(target=run).start()
def format(response):
    formatted = [response.url, "%s %s" % (response.status_code, response.reason)]
    for k,v in response.headers.items():
        formatted.append("%s: %s" % (k, v))
    formatted.append("")
    formatted.append(r.text)
    return "\n".join(formatted)
if __name__ == "__main__":
    while True:
        try:
            payload = {'grant_type': 'client_credentials', 'client_id': CLIENT_ID, 'client_secret': CLIENT_SECRET}
            print("Logging into authentication system...")
            r = requests.post(f'{AUTHENTICATION_HOST}/v1/oauth2/token', data=payload)
            assert r.status_code == 200, format(r)
            auth_token = r.json()["access_token"]
            #print("\nLogged in auth_token=(%s)" % auth_token)
            headers = {
                "Content-Type": "application/vnd.api+json",
                "x-api-key": API_KEY,
                "Authorization": "Bearer " + auth_token
            print("\n### get locations ###")
            r = requests.get(f'{SMART_HOST}/v1/locations', headers=headers)
            assert len(r.json()["data"]) > 0, 'location missing - user has not setup system'
            location_id = r.json()["data"][0]["id"]
            #print("\nLocationId=(%s)" % location_id)
            payload = {
                "data": {
                    "type": "WEBSOCKET",
                    "attributes": {
                        "locationId": location_id
                    "id": "does-not-matter"
            print("\ngetting websocket ID...")
            r = requests.post(f'{SMART_HOST}/v1/websocket', json=payload, headers=headers)
            assert r.status_code == 201, format(r)
            print("\nWebsocket ID obtained, connecting...")
            response = r.json()
            websocket_url = response["data"]["attributes"]["url"]
            websocket.enableTrace(True)  #True om raw output in display te hebben
            client = Client()
            ws = websocket.WebSocketApp(
                websocket_url,
                on_message=client.on_message,
                on_error=client.on_error,
                on_close=client.on_close)
            ws.messages_count = 0         # Create a counter and an empty list to store messages
            ws.on_open = client.on_open
            ws.run_forever(ping_interval=120, ping_timeout=3)
        except Exception as e:
            gc.collect()
            print("Websocket connection Error  : {0}".format(e))
        print("Reconnecting websocket  after 600 sec")
        time.sleep(600)
The above code was working before but i paused the domoticz integration.
Now i tried to start implementing, but when testing it i run into an ssl problem.
The response i get :
error  12:10:05
[SSL: CERTIFICATE_VERIFY_FAILED] certificate verify failed: unable to get local issuer certificate (_ssl.c:997)
[SSL: CERTIFICATE_VERIFY_FAILED] certificate verify failed: unable to get local issuer certificate (_ssl.c:997) - goodbye
closed  12:10:05,445888
### closed ###
As i am just an noob on python, it seems impossible for me to solve this ssl problem.
Maybe one of the domoticz members with python knowledge can help me out ?
Thanks in advance
Thorgal789
Re: Help needed python gardena smartwater websocket (SLL problem)
Post by Thorgal789 »
Hello, have you tried just with using "hhtp" instead of "https" ? Some API support both.
Else can try with certifi
import certifi
response = requests.get('https://your-server-url', verify=certifi.where())
Or disable verification
import requests
response = requests.get('https://your-server-url', verify=False)
zicht
Post by zicht »
thnx wil try that.
All goes well until i open de the websocket ... so will try both to see if it works.
No way arround the HTTPS ...
i need the ssl implementation on this part
client = Client()
                websocket_url,
till there its running fine.
As in the log is visible the websocket is called succesfully, but on the above part i get the SSL error.
zicht
Post by zicht »
Solvedit by :
            ws.run_forever(ping_interval=120, ping_timeout=3[b][u][i], sslopt={"cert_reqs": ssl.CERT_NONE}[/i][/u][/b])
many thanks, now lets find out how to integrate domoticz. if anyone interested, i can post updates in the forum ?
If possible make a python plugin out of it....
I believe there is already a Gardena/Husqvarna plugin but for mowers...
zicht
Post by zicht »
waltervl wrote: Sunday 12 January 2025 15:34 If possible make a python plugin out of it....
I am a bit stuck at the plugin structure and how to port into a plugin. Any possiility to point me at the mower plugin ?
Cant find it (to use it as an example would be really helpfull) but maybe i'm searching at the wrong places
As an intemediate solution :
I have compiled my python into and exe (for windows use) : that saves some processor time --> In the past i did this also for roomba with good results. It dumps values (update strings) into a text sensor and can be handled from there by handling the json textstring in a script. (If anyone interested i can disclose the files)
This is an Husqvarna mowers plugin but Gardena seems to use something similar. viewtopic.php?t=39624
