Docker automatic backup error - SOLVED Topic is solved
Forum rules
Version: xxxx
Platform: xxxx
Plugin/Hardware: xxxx
Description:
barry44
Domoticz version: 2023.1
Post by barry44 »
Version: 2024.7
Platform: Docker in bookworm raspian
Plugin/Hardware: Raspberry 4
Description:
Hello
I've recently migrated my domoticz to docker.
Everything is working fine, except automatic backup.
When the daily (or monthly or yearly) folder is empty, the file is created
But when the file already exists (for example backup-hour-16-Domoticz.db) , I get an error in log " Error: Error writing automatic hourly backup file"
My docker compose is standard one with a volume
./config:/opt/domoticz/userdata
And the config file has thoses rights
drwxr-xr-x  6 pi pi 4096  7 janv. 20:16 config
Am I missing something ? I think there is a right problem, but no idea where to search.
Thank's for your help
Domoticz version: 2024.7
Re: Docker automatic backup error
Did you install docker following the instructions here https://wiki.domoticz.com/Docker#Instal ... nux_system
Especially the command for permissions:
sudo usermod -aG docker ${USER}
barry44
Post by barry44 »
Hello
Yes, I follow this guide.
I can't really remember if I run this command. But I think so.
pi@xxxxx:~ $ sudo echo ${USER}
pi
pi@xxxxx:~ $ id
uid=1000(pi) gid=1000(pi) groupes=1000(pi),4(adm),20(dialout),24(cdrom),27(sudo),29(audio),44(video),46(plugdev),60(games),100(users),105(input),107(render),109(netdev),995(docker),997(gpio),998(i2c),999(spi
pi@xxxxx:~ $ getent group docker
docker:x:995:pi
And I have PUID and PGID set to my pi user (=1000) in docker-compose environment.
barry44
Post by barry44 »
Finally, I have solved it by deleting daily/weekly/yearly folder, and let domoticz to recreate them
Now it works normally.
I don't understand why, the permissions seem to be the same. But it works.
