Bug when creating python script
Forum rules
Version: xxxx
Platform: xxxx
Plugin/Hardware: xxxx
Description:
HvdW
Domoticz version: 2023.2
Post by HvdW »
Version: 2024.7
Platform: RPI 4
Script: self written, happens to any script
When a python script is created it is possible to choose a trigger.
Whateven trigger is chosen there is no option to fill out a trigger.
Script voor het monitoren van EV laadgegevens
Triggers:
    - time = "At 09:00 on Sunday"
    - device = "Charging Level"
#!/usr/bin/env python
import DomoticzEvents as DE
import datetime
import csv
import os
from statistics import mean
class EVChargingMonitor:
    def __init__(self):
        self.BATTERY_CAPACITY = 79  # kWh
        self.CSV_FILE = '/home/hein/car-charging.csv'
        self.previous_level = None
        self.odometer_readings = []
        self.whtotal_readings = []
        self.temp_readings = []
    def on_start(self):
        # Initialize if file doesn't exist
        if not os.path.exists(self.CSV_FILE):
            with open(self.CSV_FILE, 'w', newline='') as f:
                writer = csv.writer(f, delimiter=';')
                writer.writerow(['datum', 'odometer', 'afstand', 'kWh', 'euro', 'average temp'])
    def calculate_weekly_consumption(self):
        if not self.odometer_readings or not self.whtotal_readings:
            return None
        # Calculate distance between first and last reading
        start_odometer = self.odometer_readings[0]
        end_odometer = self.odometer_readings[-1]
        distance = end_odometer - start_odometer
        # Calculate energy consumption
        start_whtotal = self.whtotal_readings[0]
        end_whtotal = self.whtotal_readings[-1]
        energy_consumed = (end_whtotal - start_whtotal) / 1000  # Convert Wh to kWh
        # Calculate average temperature
        avg_temp = mean(self.temp_readings) if self.temp_readings else None
        # Calculate cost (assuming €0.25 per kWh - adjust as needed)
        cost = energy_consumed * 0.25
            'timestamp': datetime.datetime.now().strftime('%d-%m-%Y %H:%M'),
            'odometer': end_odometer,
            'distance': distance,
            'kwh': energy_consumed,
            'euro': cost,
            'avg_temp': avg_temp
    def save_to_csv(self, data):
        with open(self.CSV_FILE, 'a', newline='') as f:
            writer.writerow([
                data['timestamp'],
                data['odometer'],
                data['distance'],
                f"{data['kwh']:.3f}",
                f"{data['euro']:.2f}",
                f"{data['avg_temp']:.1f}" if data['avg_temp'] is not None else ''
    def update_display(self, data):
        display_text = f"""Wekelijkse verbruiksrapportage:
Datum/tijd: {data['timestamp']}
Eindstand: {data['odometer']} km
Afstand deze week: {data['distance']} km
Verbruik deze week: {data['kwh']:.3f} kWh
Kosten deze week: €{data['euro']:.2f}
Gem. temperatuur: {data['avg_temp']:.1f}°C"""
        domoticz.devices['Charging Display'].Update(nValue=0, sValue=display_text)
        # Log to Domoticz
        domoticz.log(f"EV Weekly Report: {display_text}")
    def on_time(self):
        # Deze functie wordt alleen opgeroepen op zondag 09:00
        data = self.calculate_weekly_consumption()
        if data:
            self.save_to_csv(data)
            self.update_display(data)
            # Reset weekly data
    def on_charging_level_change(self):
        # Deze functie wordt alleen opgeroepen bij wijziging van Charging Level
        current_level = domoticz.devices('Charging Level').levelVal
        if self.previous_level != current_level:
            # Sla huidige metingen op
            self.odometer_readings.append(domoticz.devices('Volvo-Odometer').nValue)
            self.whtotal_readings.append(domoticz.devices('Laadpaal').Whtotal)
            self.temp_readings.append(float(domoticz.devices('Buitentemperatuur').sValue))
            self.previous_level = current_level
# Global instance
monitor = EVChargingMonitor()
def onStart():
    monitor.on_start()
# Wordt alleen opgeroepen op zondag om 09:00
def onTime():
    monitor.on_time()
# Wordt alleen opgeroepen bij wijziging van Charging Level
def onDeviceChanged(unit, device):
    if device.name == 'Charging Level':
        monitor.on_charging_level_change()
Bugs bug me.
Domoticz version: 2024.7
Re: Bug when creating python script
There is no option to set specific triggers in Python scripting like in dzvents.
As stated in the wiki https://wiki.domoticz.com/Python_Events the triggers are:
All - Will run whenever anything happens that triggers the event system to run a script
Device - Will run whenever ANY device state/value change
Security - Will run whenever there is a security event
Time - Will run once per minute. Scripts are executed one at a time.
User Variable - Will run when User Variables are updated
You have to check in the script yourself if time is as set. So if you want to run the script at 21:00 the first part of the script will be the check if time = 21:00. If not stop the script else continue.
The same for a device change, first check it the changed device is the one you want to handle. If so continue, else stop.
