Display problem in phpBB
mgugu
Post by mgugu »
There is a small cosmetic problem in phpBB.
When I change the page number, display is not updated and increment does not work.
2025-01-02 13_14_10-Domoticz - Index page – .jpg (8.63 KiB) Viewed 1035 times
Tested with different browsers.
gizmocuz
Re: Display problem in phpBB
Post by gizmocuz »
You mean when you press '5', it does not highlight 5? That happens here...
Maybe clear your browser cache, try in private mode?
Using 'Edge' here
mgugu
Post by mgugu »
gizmocuz wrote: Thursday 02 January 2025 13:56 You mean when you press '5', it does not highlight 5? That happens here...
Using 'Edge' here
Exactly, private mode does not change. Same problem on my Android smartphone.
Very strange !
Egregius
Domoticz version: v2024.7
Post by Egregius »
I see the same issue in Chrome and Safari on MacOS and Chrome, Firefox and Edge on Windows. Each test was done in a private browsing window.
Domoticz version: 2024.7
Works for me on Android Firefox
Additional, it works correct when logged in.
When NOT logged it shows always page 1 after selecting another page.
mgugu
Post by mgugu »
Logged or not, I get the same issue
andreo
Domoticz version: 2024.3
Post by andreo »
I've been having this same problem ever since the snowflakes and Santa hats came into the picture
Latest version of Domoticz and more running on Docker|Raspberry Pi 4-B 8GB Bookworm|RF-Link|Klik Aan Klik Uit|Nefit easy|ESPeasy|P1 power meter|S0PCM-5 through Ser2Net|Alecto WS5500|FrtizBox|Satel Integra|Solis
Greetz Andre.
andreo wrote: Friday 03 January 2025 0:27 I've been having this same problem ever since the snowflakes and Santa hats came into the picture
Those are switched off now.... Is it working again?
Egregius
Post by Egregius »
You sure? If I open a private window I still get the snow. Used a private window because that's disabled in my profile.
gizmocuz
Post by gizmocuz »
It's still freezing outside, changes of snow are there....
Ok, seems when not logged it, there is an issue with the bullets indeed.
So, the solution is to login for now...
Egregius
Post by Egregius »
It also happens when logged in...
HansieNL
Post by HansieNL »
Brrr... I tried to find the "Disable snowing" button, but without succes ;-)
Logged in Firefox Focus on iPad and problem too with the bullets. Looks like it happens only on frontpage.
Blah blah blah
andreo
Post by andreo »
waltervl wrote: Friday 03 January 2025 9:29
After deleting the cache the problem persists. it makes no difference whether you are logged in or not.
Greetz Andre.
It looks to be a bug in phpBB (or a phpBB plugin) so hopefully it will be solved in a newer version of the forum soon.
