Dashticz not working need help
sailmich
Happy new year!
I'm not sure if it is a bug in domoticz, dashticz or something wrong with my RPi4
I run domoticz beta and dashticz beta on the same RPi 4 for months. After an update of domoticz in the last days I got "error for more help visit Dashticz v3 documentation" on my wall tablet. I usually work with domoticz on my phone, after trying open dashticz on my phone I got the same fault. I tried also open dashticz on my notebook with firefox. Sometimes dashticz get open sometimes not. I checked with developer console in firefox this delivers an error at logincheck. Could this be the cause?
Domoticz and dashticz are on newest beta. RPi 4 is updated too. Any help appreciated.
Lokonli
Re: Dashticz not working need help
If you've updated from an older Domoticz version then this probably is caused by changes in Domoticz authentication mechanisms.sailmich wrote: Wednesday 01 January 2025 12:51 Happy new year!
In Domoticz you have to add the IP address, or subnet, of your Dashticz notebook to Domoticz->Settings->Security->Trusted network.
Or add the correct Domoticz user name and password to your Dashticz CONFIG.js.
You also have to update Dashticz to a recent version (latest master or beta will work)
sailmich
Hello Lokonli,In Domoticz you have to add the IP address, or subnet, of your Dashticz notebook to Domoticz->Settings->Security->Trusted network.
thx für answering, but all of this I already have before the issue appered. It's in the trusted network, user name and password are in CONFIG.js and dashticz is newest version.
pquinqu
- Domoticz version: 2024.7
Hi, this is m'y first post here.
I had the same issue few days ago.
Into the debugger, I noticed a timeout on the initial loading of Dashticz, when requesting all domoticz devices with a web socket connection in domoticz_api.is.
Setting enable_websocket to false in the config section of the CONFIG.js file fixed the issue for me.
It seems that a parseFloat on the Domoticz version enable websockets and this doesn't work in my nginx docker conf.
Hope that help. Have a nice year
Phil
Phil
Lokonli
Can you post the log info (user messages) from DevTools?
- Domoticz version: 2026.3
Warning, in latest beta the API backward compatibility code has been removed. Perhaps this is causing some issues.....Lokonli wrote: Wednesday 01 January 2025 20:03 Can you post the log info (user messages) from DevTools?
https://github.com/domoticz/domoticz/co ... dfa0c48375
pquinqu
Hi lokonli, waltervl,waltervl wrote: Wednesday 01 January 2025 21:21Warning, in latest beta the API backward compatibility code has been removed. Perhaps this is causing some issues.....Lokonli wrote: Wednesday 01 January 2025 20:03 Can you post the log info (user messages) from DevTools?
Can you consider my post above. I fixed the issue with config["enable_websocket"]=false in the CONFIG.js dashticz file.
It seems that Dashticz try to establish a websocket connection to Domoticz after parsing 2024.7 domoticz version, which enables websockets.
The promise fails in timeout as it's in pending state in domoticz_api.js.
I am not fluent in js, but I guess this is the issue.
Say me if I'm wrong
Phil
Lokonli
Because of a recent Domoticz change indeed the websocket interface in Dashticz is broken.pquinqu wrote: Wednesday 01 January 2025 21:59Hi lokonli, waltervl,waltervl wrote: Wednesday 01 January 2025 21:21Warning, in latest beta the API backward compatibility code has been removed. Perhaps this is causing some issues.....Lokonli wrote: Wednesday 01 January 2025 20:03 Can you post the log info (user messages) from DevTools?
Say me if I'm wrong
Phil
Work around as posted by Phil is to add the following to CONFIG.js:
sailmich
Thank you very much to all of you! It's working with the work around.
Cheers
Cheers
- kiddigital
Any idea already @Lokonli what is not working anymore? After some debugging and testing I could not found anything wrong.. WebSocket seems to work as normal.. I do not get any timeouts or something.. and see continues updates...Lokonli wrote: Thursday 02 January 2025 7:49Because of a recent Domoticz change indeed the websocket interface in Dashticz is broken.
Work around ...
I'll analyze the issue.
Lokonli
Excellent!kiddigital wrote: Sunday 27 April 2025 20:00Any idea already @Lokonli what is not working anymore? After some debugging and testing I could not found anything wrong.. WebSocket seems to work as normal.. I do not get any timeouts or something.. and see continues updates...
Indeed working again with a recent Domoticz version.
Maybe fixed as part of the following commit? https://github.com/domoticz/domoticz/pull/5918
