difference between mqtt lan and mqtt auto discovery
Posted: Saturday 28 December 2024 13:41
by rron
I want to send the S0 counter from my espeasy to domoticz via mqtt. I want it to sent it via mqtt auto discovery client gateway with lan. There 's no error on the espeasy for bouncing and I can see it also in the mqtt explorer. But it never appears in the auto discovery, and except new hardware is on.
Then I tried the mqtt lan client gateway and there it 's appearing.
My question is what is the difference between those two mqtt settings? If you look at the settings tab in mqtt there 's also a different kind of devices detected. The auto discovery can see 167 rules and the mqtt lan can see only 92 rules, but some different devices.
Domoticz is on the latest stable version 2024.7 and espeasy on mega-20240414
Re: difference between mqtt lan and mqtt auto discovery
Posted: Saturday 28 December 2024 15:07
by gizmocuz
Maybe ESPEasy does not support the Home Assistant MQTT Auto Discovery protocol?
You could create your own config topic/payload to get it supported
Best to go to the Home Assistant website and check the MQTT AD documentation how to do so
Posted: Saturday 28 December 2024 15:17
by rron
Looks like it. But then you advice to use only one mqtt protocol and not auto discovery and mqtt client at the same time?
Posted: Saturday 28 December 2024 15:37
by gizmocuz
Nope. If you don't use basic MQTT for anything else in Domoticz, I would go the MQTT AD way.
But if I google for ESPEasy in combination with MQTT Auto Discovery I get a lot of website responses.
You can also use ESPHome for your S0 meter
Posted: Saturday 28 December 2024 19:48
by akamming
rron wrote: Saturday 28 December 2024 13:41
You have to read the espeasy documentation.
The device Will not be autocreated. Espeasy does not support autodiscovery
So what you need to do is
- create a virtual device in domoticz
- configure the espeasy device so that it updates that device. It Will then send commands on the domoticz/in topic
Although espeasy also supports the update to domoticz via http. This way you don’t need to configure Mqtt
Posted: Saturday 28 December 2024 20:15
by rron
akamming wrote: Saturday 28 December 2024 19:48
Yes I have red this documentation and I thought that it was already inplementated. The http update already worked by me but I wanted to keep it uniform and since I already had mqtt autodiscovery. It also worked wih the standard mqtt.
Auto discovery is work in progress for espeasy.
Posted: Sunday 29 December 2024 8:30
by BartSr
Posted: Sunday 29 December 2024 8:48
by akamming
rron wrote: Saturday 28 December 2024 20:15
But then you should know the anwser to your original question: you use the mqtt autodiscovery interface
The mqtt lan interface is the domoticz/in and domoticz/out interface.
Posted: Sunday 29 December 2024 10:35
by rron
Yes I know but I thought that i overlooked something. One off the questions where can i use those two together
Posted: Sunday 29 December 2024 13:57
by gizmocuz
So maybe switch to ESPuna of ESPHome?
Posted: Sunday 29 December 2024 14:22
by BartSr
@Gizmocuz
What's ESPuna?
Posted: Sunday 29 December 2024 14:58
by rron
I switched back to espeasy on http. That works ok. I will wait until mqtt auto discovery is implemented.
Posted: Sunday 29 December 2024 17:18
by gizmocuz
Sorry, meant 'espurna32', but you're probably better of with ESPHome, just install it in a docker compose environment
