difference between mqtt lan and mqtt auto discovery
rron
Post by rron »
I want to send the S0 counter from my espeasy to domoticz via mqtt. I want it to sent it via mqtt auto discovery client gateway with lan. There 's no error on the espeasy for bouncing and I can see it also in the mqtt explorer. But it never appears in the auto discovery, and except new hardware is on.
Then I tried the mqtt lan client gateway and there it 's appearing. :?:
My question is what is the difference between those two mqtt settings? If you look at the settings tab in mqtt there 's also a different kind of devices detected. The auto discovery can see 167 rules and the mqtt lan can see only 92 rules, but some different devices. :shock:
Domoticz is on the latest stable version 2024.7 and espeasy on mega-20240414
gizmocuz
Re: difference between mqtt lan and mqtt auto discovery
Post by gizmocuz »
Maybe ESPEasy does not support the Home Assistant MQTT Auto Discovery protocol?
You could create your own config topic/payload to get it supported
Best to go to the Home Assistant website and check the MQTT AD documentation how to do so
rron
Post by rron »
Looks like it. But then you advice to use only one mqtt protocol and not auto discovery and mqtt client at the same time?
gizmocuz
Post by gizmocuz »
Nope. If you don't use basic MQTT for anything else in Domoticz, I would go the MQTT AD way.
But if I google for ESPEasy in combination with MQTT Auto Discovery I get a lot of website responses.
You can also use ESPHome for your S0 meter
akamming
Post by akamming »
rron wrote: Saturday 28 December 2024 13:41 I want to send the S0 counter from my espeasy to domoticz via mqtt. I want it to sent it via mqtt auto discovery client gateway with lan. There 's no error on the espeasy for bouncing and I can see it also in the mqtt explorer. But it never appears in the auto discovery, and except new hardware is on.
You have to read the espeasy documentation.
The device Will not be autocreated. Espeasy does not support autodiscovery
So what you need to do is
- create a virtual device in domoticz
- configure the espeasy device so that it updates that device. It Will then send commands on the domoticz/in topic
Although espeasy also supports the update to domoticz via http. This way you don’t need to configure Mqtt
rron
Post by rron »
akamming wrote: Saturday 28 December 2024 19:48
Yes I have red this documentation and I thought that it was already inplementated. The http update already worked by me but I wanted to keep it uniform and since I already had mqtt autodiscovery. It also worked wih the standard mqtt.
Auto discovery is work in progress for espeasy.
BartSr
Domoticz version: V2024.7
Post by BartSr »
Raspberry pi 3b
Arduino
KAKU
RfxCom
Zwave2MQTT
OTGW
Tasmota
Esp8266 / 32 espeasy
Zigbee2MQTT
akamming
Post by akamming »
rron wrote: Saturday 28 December 2024 20:15 Yes I have red this documentation and I thought that it was already inplementated. The http update already worked by me but I wanted to keep it uniform and since I already had mqtt autodiscovery. It also worked wih the standard mqtt.
But then you should know the anwser to your original question: you use the mqtt autodiscovery interface
The mqtt lan interface is the domoticz/in and domoticz/out interface.
rron
Post by rron »
Yes I know but I thought that i overlooked something. One off the questions where can i use those two together
gizmocuz
Post by gizmocuz »
So maybe switch to ESPuna of ESPHome?
BartSr
Post by BartSr »
@Gizmocuz
What's ESPuna?
Raspberry pi 3b
Arduino
KAKU
RfxCom
Zwave2MQTT
OTGW
Tasmota
Zigbee2MQTT
rron
Post by rron »
I switched back to espeasy on http. That works ok. I will wait until mqtt auto discovery is implemented.
gizmocuz
Post by gizmocuz »
Sorry, meant 'espurna32', but you're probably better of with ESPHome, just install it in a docker compose environment
