which files can be deleted safe from raspberry?
BartSr
Domoticz version: V2024.7
Post by BartSr »
Content on my raspberry 3+ sd card is growing
4,4G	/var
1,7G	/var/log
1,5G	/var/log/journal/9ad0dc29f0a2458cb78c7496645eb372
1,5G	/var/lib
1,4G	/var/lib/docker
1,2G	/var/cache/apt
1,2G	/var/cache
1,1G	/var/cache/apt/archives
930M	/var/lib/docker/overlay2
Is it safe to delete these files being the biggest ones
info retrieved with command:
sudo du -ah /var | sort -rh | head -1- > textfile.txt
TIA
Bart
Raspberry pi 3b
Arduino
KAKU
RfxCom
Zwave2MQTT
OTGW
Tasmota
Esp8266 / 32 espeasy
Zigbee2MQTT
Kedi
Re: which files can be deleted safe from raspberry?
Post by Kedi »
Probably your journal files are growing.
You can restrict that -> search for howto on the Internet.
Cache files can be deleted, but I don't think those will grow fast.
With the right commands you can delete unused / unwanted docker images if you want, again search the Internet.
All the other files should be untouched, most of them are there for a reason.
The command you used displays directories not files.
Egregius
Domoticz version: v2024.7
Post by Egregius »
/var/log should be easy to clean.
And I suppose /var/cache/apt with "apt clean".
WouterO
Post by WouterO »
This is my safe vacuum cleaner on my RPi:
sudo apt autoclean && sudo apt clean && sudo apt autoremove -y && sudo journalctl --vacuum-time=2d
Kedi
Post by Kedi »
For journalctl beter put the right instructions in /etc/systemd/journald.conf
Like SystemMaxUse=100M and SystemKeepFree=1G
Then you are done for the future.
