How to use the install.domoticz.com script to install not the latest version?
Posted: Thursday 05 December 2024 23:12
by user4563
By default the script at install.domoticz.com will install the latest version. I want to use the script to install v2023.2 as I would like the transfer my v2023.2 from Windows to my Ubuntu server and stay on the same version.
Looking through the script, I see line 380 which is:
wget -O domoticz_release.tgz "http://www.domoticz.com/download.php?channel=release&type=release&system=${OS}&machine=${MACH}"
and if I change it to the following I'll d/l v2023.2:
wget -O domoticz_release.tgz "https://github.com/domoticz/domoticz/releases/download/2023.2/domoticz_linux_2023.2_x86_64.tgz"
Is anyone familiar with the script know if that's all I need to change?
Re: How to use the install.domoticz.com script to install not the latest version?
Posted: Friday 06 December 2024 1:04
by HvdW
Posted: Friday 06 December 2024 21:53
by user4563
Thank you... I did replace the link to download "domoticz_linux_2023.2_x86_64.tgz". Are you aware of anything else required to change in the script?
Posted: Saturday 07 December 2024 8:04
by gizmocuz
Why would you need/want to run such an old version?
Posted: Saturday 07 December 2024 16:57
by user4563
I want v2023.2 due to OpenZWave. When OpenZWave was added back it lost some capability with my older thermostats. This is the easier path for now versus replacing thermostats or when I finally migrate to ZWaveJS.
Posted: Friday 27 December 2024 23:15
by user4563
Ok after first installing libssl1.1 (
viewtopic.php?t=42200 ) and then changing the line in the script it did install 2023.2 successfully.
However, OZW is not in the list. Wasn't v2023.2 the last version to have it?
- Screenshot 2024-12-27 171439.jpg (70.61 KiB) Viewed 1596 times
Posted: Saturday 28 December 2024 15:18
by gizmocuz
OpenZWave is in the latest version.
But better to migrate to ZwaveJS-UI with MQTT Auto Discovery, and while your doing so, maybe switch to the docker compose version of Domoticz as well so you don't have issues with ssl libraries in the feature
Posted: Monday 30 December 2024 22:19
by user4563
gizmocuz wrote: Saturday 28 December 2024 15:18
I completely agree and the migration to ZwaveJS-UI will be something I will have to tackle in the future.
I tried the latest versions with the return on OpenZWave and for some reason the thermostat modes and fans do not display in the "Utility" tab. If I downgrade they come back. Since OZW hasn't changed something changed in the program from v2023.2 to v2024.2. Nothing stood out in the changlogs. Any idea what changed or how to solve?
v2024.7 :
- Screenshot 2024-12-30 144041.jpg (195.44 KiB) Viewed 1502 times
v2023.1 :
- Screenshot 2024-12-30 153959.jpg (314.44 KiB) Viewed 1502 times
