Python Plugin: Sessy battery
JanJaap
Domoticz version: Dev
Post by JanJaap »
Hey all,
I'm creating a new plugin for the (Dutch) Sessy batteries. It's working quite ok so far, check my github if you want.
I have some questions for adding it to the energy dashboard:
I'm creating the following power related units:
        if deviceId not in Devices or (self.batEnergyDeliveredUnit not in Devices[deviceId].Units):
            Domoticz.Unit(Name=deviceId + " - Battery delivered power", Unit=self.batEnergyDeliveredUnit, Type=243, Subtype=29, Switchtype=4, Used=1, DeviceID=deviceId).Create()
        if deviceId not in Devices or (self.batEnergyStoredUnit not in Devices[deviceId].Units):
            Domoticz.Unit(Name=deviceId + " - Battery stored power", Unit=self.batEnergyStoredUnit, Type=243, Subtype=29, DeviceID=deviceId).Create()
        if deviceId not in Devices or (self.batPowerUnit not in Devices[deviceId].Units):
            Domoticz.Unit(Name=deviceId + ' - Battery in/output power', Unit=self.batPowerUnit, Type=250, Subtype=1, DeviceID=deviceId).Create()
As I understood that the type 243 can only take energy flow in one direction (so in or out of battery). But when I want to configure the energy dashboard, only the type 243's are selectable. How do I set this up best in the plugin? Can I enter negative values into the 243?
Domoticz version: 2025.1
Re: Python Plugin: Sessy battery
243 is Electricity (instant and counter)? Then it can take positive and negative values. I use it to monitor my normal grid usage as I do not have a P1 smart meter. And I have solar panels, so negative values (negative usage in Watt and rolling back counter Wh) are possible
JanJaap
Post by JanJaap »
ok tnx, then I'll rework it
JanJaap
Post by JanJaap »
@walter Somehow it does not seem to work. I created the device as follows:
        if deviceId not in Devices or (self.batEnergyUnit not in Devices[deviceId].Units):
            # set switchtype to 4/exporting as positive is going out of battery (so producing)
            Domoticz.Unit(Name=deviceId + ' - Battery energy', Unit=self.batEnergyUnit, Type=243, Subtype=29, Switchtype=4, Options={'EnergyMeterMode': '1' }, Used=1, DeviceID=deviceId).Create()
When I feed it a negative power value, no update is recorded... In fact when feeding positive as well...... I'm giving '1' for energy as that should be ignored?
<update> When removing the calculated mode and instead feeding counter value, it works.....
The zigbee4domoicz plugin is able to send negative watt values. The calculation mode for energy has an issue when plugin is used, see PR https://github.com/domoticz/domoticz/pull/6183
