Publishing to domoticz/in, no errors in log but svalue1 is always received as ZERO
lazyoldjack
Post by lazyoldjack »
So, I am publishing this:
"command": "udevice",
"idx": 123,
"stype": "SetPoint",
"nvalue": 0,
"svalue1":"17",
"unit": 1
Domoticz log says this:
2024-11-23 10:03:44.734 Updating SetPoint device....
2024-11-23 10:03:44.741 Dummy Thermostat: Setpoint (Dressing Room Setpoint)
But the value of the setpoint has been set to 0.0 :shock:
I have been stuck at this point for two days, trying all sorts and Googling a lot. I feel that someone must have seen this before, but I cannot find it.
Any help would be much appreciated :D
Domoticz version: 2025.1
Re: Publishing to domoticz/in, no errors in log but svalue1 is always received as ZERO
svalue1 should be svalue
This should be enough to update the setpoint device:
{"command":"udevice", "idx":123, "svalue":"17"}
lazyoldjack
Wow, thank you Walter! I guess I don't understand the difference between svalue and svalue1, but I am up and working now. :D
Thank you so much for your quick reply!!
domoticz\in only knows svalue (=string value), which can be multiple values depending on the device type eg
svalue" : "90;2975.00"
domoticz\out splits the svalue into 1 or more seperate values svalue1, 2 3 etc also depending on the device. This for easier processing in other receiving applications.
