Access to LOG data using dzVents
Tukker
Domoticz version: 2023.2
Post by Tukker »
Is it possible to read the log data of a switch using dzVents?
2024-11-21 06:59:01	Off	timer
2024-11-21 00:01:01	On	timer
2024-11-20 06:59:01	Off	timer
2024-11-20 00:01:01	On	timer
2024-11-19 06:59:01	Off	timer
These data.
Bugs bug me.
Re: Access to LOG data using dzVents
Depends what you want to do with it.
If you want to get the data from database I do not believe it can be read. Perhaps there is an API call for it but as far as I know not documented.
On the other side you can store the log value in dzvents persistent data while monitoring the switch so you can do the evaluation on the dzvents data. There are some examples of this somewhere on this forum. But you can always ask ChatGPT or Copilot for a clever answer :-)
FlyingDomotic
Post by FlyingDomotic »
There's an undocumented API,responding at http://<domoticz_ip>:<domoticz_port>/json.htm?idx=<deviceIdx>&type=lightlog
This may change at every new version, use it at your own risk.
IMHO, keeping changes in a persistent dzVents data, as suggested, is probably the best solution.
