CommandArray command in LUA doesn't work anymore Topic is solved
Forum rules
Version: xxxx
Platform: xxxx
Plugin/Hardware: xxxx
Description:
sebitop
Post by sebitop »
Dear All
again this error happening either on Release or Beta version
I have a VIRTUAL SWITCH called DEBUG
I just run this code:
if (otherdevices['DEBUG']) == 'On' then
print('debug')
commandArray['DEBUG'] = 'Off'
Debug appears in the LOG
command array is not executed and the switch remains ON
any ideas ?
thansk again for your help !!
cheers
sebastien
domoticz on Raspberry Pi + RFXcom LAN moded + wifi
Blyss / DI.O / homemade / ESP / wemos
jvdz
Domoticz version: 4.107
Re: CommandArray command in LUA doesn't work anymore
Post by jvdz »
Is that your whole script?
Please show the total script.
sebitop
Post by sebitop »
commandArray ={}
print('debug')
it seems that my modifications on the meter calendar DB have an issue on this behavior as trying a previous day save seems to work but this does not explain why it does that
Last edited by sebitop on Wednesday 13 November 2024 22:54, edited 1 time in total.
jvdz
Post by jvdz »
That last line is wrong as the arrayname has a typo, so nothing is returned!
sebitop
Post by sebitop »
it was a typo here
on my LUA the code is correct
sebitop
Post by sebitop »
I restored previous adatabase
It worked until this morning again the same issue....
jvdz
Post by jvdz »
Typo?
Just show us the real code, not something typed, doing a cut&paste so we can check the code for issues. ;)
sebitop
Post by sebitop »
I'm trying to replicate the error finding which activation generates this issue as restoring a previous DB saved works well
nothing related to the domoticz version itself, behavior is the same with a stable or beta version
Do you have any idea of what could generate an issue preventing the commandArray command working on domoticz?
could it be linked to the database ?
I'm wondering as I have seen something this morning :
I have a script which works well since months and the aim is to retreive the color code of the french electricity (pricing is based on a color which changes every day)
this script parses an http address with JSON and extracts the color
but I realised that this morning the HTTP address was not reacheable showing an error message (error 403) but the JSON parsed some HTTP code and raised an error in the log
after I also realized that Domoticz was not working again
then I suspect this like an http injection things like tha
so now I'm searching what could have an impact in the DB that could stop CommadArray commands working
I need some additional tests to find exactly when it fails
I know this one is not an easy but I'm struggling to find out
thanks again for reading ;)
Last edited by sebitop on Thursday 14 November 2024 22:29, edited 1 time in total.
lost
Post by lost »
sebitop wrote: Thursday 14 November 2024 10:19 I have a script which works well since months and the aim is to retreive the color code of the french electricity (pricing is based on a color which changes every day)
If you are using RTE Tempo data, server was unavailable this morning until ~8h45:
https://easydomoticz.com/forum/viewtopi ... 78#p122778
No issue on my side, as I do a quick check to see if answer starts with '{' as a JSON should, from the function that gets data:
-- Internal fct :
-- Get json answer EDF or RTE http/json API.
local function getUrlJson(url)
    config = assert(io.popen('curl --retry 1 --connect-timeout 2 -m 4  \"'..url..'\"'))
    data   = config:read('*all')
    config:close()
    -- Quick check answer is in JSON format
    if data:sub(1, 1) == "{" then
        jsonOut = json:decode(data)
        jsonOut = nil
    return(jsonOut)
Then if I get a 'nil' return a warning is logged and data is discarded (default values showing undefined day color/prices are used):
    -- Get all data for current tempo season
    tempoSeasonURL  = 'https://www.services-rte.com/cms/open_data/v1/tempo?season='..tempoSeason
    tempoSeasonData = getUrlJson(tempoSeasonURL)
    if (tempoSeasonData == nil) then
        print("TEMPO : Warning, no data/color received from RTE ; Network issue?")
        return tempoDay, tempoCount
That's not a foolproof check (the provided JSON.lua to handle this format does not provide such validation), but at least this avoids going ahead & depending on your data parsing code, the possibility (in my case, further checks exists anyway & not matching expected JSON format => no update) to feed DB with crap data through a virtual sensor for instance.
If you don't validate data & can feed crap to Domoticz, I'm afraid but your code is not "correct".
sebitop
Post by sebitop »
lost wrote: Thursday 14 November 2024 12:05 If you don't validate data & can feed crap to Domoticz, I'm afraid but your code is not "correct".
It's probably the case and maybe this is what is causing the issue and blocking the CommandArray
the only things that changed since a couple of days is the RTE website being down
I will try to check this JSON like you did and restore domoticz from a previous working DB and see if it changes
thanks again for the code really helpful will test it
cheers
seb
sebitop
Post by sebitop »
Ok so after a couple of hours debugging here is the mystery but I found from where it comes
so first thanks for the JSON check, the issue is not coming from here but now the EDF JSON is perfectly parsed thanks again
now my problem :
I have a script called global from where I launch other scripts function of the time or other conditions, no issue so far
in this file there is a part of the code as following :
	if otherdevices[getdevicename(1631)] == 'On' then
		dofile('/home/pi/domoticz/scripts/lua/script_chauffageauto.lua')
		print('[ MESSAGE ] ► Gestion chauffage automatique ON')
		print('[ MESSAGE ] ► Gestion chauffage automatique OFF')
the script_chauffageauto.lua code is :
commandArray={}
now here is the behavior :
  • if the condition is ON and the dofile executed = CommandArray STOP WORKING
  • if the condition is OFF the dofile is bypassed = commandarray WORKS
  • if I remove the code from the script_chauffageauto.lua (so empty script) = commandarray WORKS
  • if I rename script_chauffageauto.lua by script_time_chauffageauto.lua = Commandarray WORKS
  • if I comment the dofile line --XXX = commandarray WORKS
I'm totally lost as some other dofile commands in the rest of the code are correctly executed without any issue
if you have any idea or want me to do some tests feel free to tell me
thanks !
seb
jvdz
Post by jvdz »
Ofcourse! The dofile needs to be looked at as putting the code from that file at the line of the dofile statement. This means you are clearing the commandArray variable at that time and end the script execution with the return in the dofile.
So do not use the commandArray = {} and return commandArray lines in the dofile!
sebitop
Post by sebitop »
Damn yes the position of this dofile was clearing the CommandArray table and this is why no command were executed after in domoticz
a so small thing !
thanks a million you saved my night :)
zicht
Domoticz version: 2023.1+
Post by zicht »
You could use something like :
package.path = package.path .. ';' .. 'C:/PROGRA~2/domoticz/scripts/lua/functions.lua;'
local my1 = require ("functions")
at the firstrow in your script.
Then in the file functions.lua you could create as many functions as you want :
function chauffage(var1, var 2, var3)
	... do something with the var
return "Ok"
function anothersomething()
	do something else....
this way you will be able to directly pass variables and call it as you need it like and ecen get returnvalues :
x=chauffage("On","1234", "ABCD")
anothersomething()
This way your code and functions get separated and your code is nice and clean.
No need to worry for commandArray in your functions.lua file, as this is handled on the calling script.
