only once set text in text-device
Posted: Sunday 03 November 2024 21:27
by BartSr
I intend to use text devices on floorplan as 'labels'
What is best way to set text in textdevice only once?
Re: only once set text in text-device
Posted: Monday 04 November 2024 0:35
by solarboy
In dzvents
domoticz.devices('My Text Device').updateText('The Text I want to show')
Posted: Monday 04 November 2024 8:06
by waltervl
Or with a API call:
/json.htm?type=command¶m=udevice&idx=IDX&nvalue=0&svalue=TEXT
IDX = id of your device (This number can be found in the devices tab in the column "IDX")
TEXT = Text you want to display
https://www.domoticz.com/wiki/Domoticz_ ... ext_sensor
Posted: Monday 04 November 2024 8:18
by BartSr
thanks Walter. But how to run this code only once dz starts?
Posted: Monday 04 November 2024 8:52
by waltervl
BartSr wrote: Monday 04 November 2024 8:18
If you mean the dzvents line, that was not mine proposal. If you want to use dzvents just make a script that runs every minute. Run that line or multiple lines for multiple text devices and stop the script after a few minutes (disable it).
Once the text is in the database there is no need to update the text devices, even after a restart of Domoticz.
