I intend to use text devices on floorplan as 'labels'
What is best way to set text in textdevice only once?
only once set text in text-device
BartSr
- Domoticz version: V2024.7
Raspberry pi 3b
Arduino
KAKU
RfxCom
Zwave2MQTT
OTGW
Tasmota
Esp8266 / 32 espeasy
Zigbee2MQTT
Arduino
KAKU
RfxCom
Zwave2MQTT
OTGW
Tasmota
Zigbee2MQTT
solarboy
- Domoticz version: 2026.4
Re: only once set text in text-device
In dzvents
domoticz.devices('My Text Device').updateText('The Text I want to show')Intel NUC with Ubuntu Server VM (Proxmox),mosquitto(docker),RFXtrx433E,zwavejsUI (docker),Zigbee2mqtt(docker),Harmony Hub, Kodi,APC UPS,SMA Modbus,Broadlink,Dombus
- Domoticz version: 2026.3
Or with a API call:
IDX = id of your device (This number can be found in the devices tab in the column "IDX")
TEXT = Text you want to display
https://www.domoticz.com/wiki/Domoticz_ ... ext_sensor
/json.htm?type=command¶m=udevice&idx=IDX&nvalue=0&svalue=TEXTTEXT = Text you want to display
BartSr
thanks Walter. But how to run this code only once dz starts?
Raspberry pi 3b
Arduino
KAKU
RfxCom
Zwave2MQTT
OTGW
Tasmota
Zigbee2MQTT
Arduino
KAKU
RfxCom
Zwave2MQTT
OTGW
Tasmota
Zigbee2MQTT
If you mean the dzvents line, that was not mine proposal. If you want to use dzvents just make a script that runs every minute. Run that line or multiple lines for multiple text devices and stop the script after a few minutes (disable it).BartSr wrote: Monday 04 November 2024 8:18 thanks Walter. But how to run this code only once dz starts?
Once the text is in the database there is no need to update the text devices, even after a restart of Domoticz.
