Floorplan and other menus can not be set
Backbone
Domoticz version: 2023.2
Post by Backbone »
I want to add and change a floorplan but it is not in the top menubar.
I cant select any menu to be active.
Is Domoticz trunkated?
Or do I look in the wrong place?
Paco
Re: Floorplan and other menus can not be set
Tab showing is a user setting so go to menu Setup - Users and enable the floorplan tab for the user(s) you use.
https://www.domoticz.com/wiki/User_Management
Edit: I saw that on the Floorplan wiki there still was an instruction for the old way of setting tabs... Now corrected. https://www.domoticz.com/wiki/Floorplans
Backbone
Post by Backbone »
Thanks Walter,
I will check this evening.
Paco
