Hello all,
I am a Domoticz user for years now and have pretty much everything automated at home. I read on the Forum that the Medisana Scale could be added to Domoticz.. searched the Forum.. searched the Internet.. I am on a Raspberry Pi Domoticz version 4.116.
I read that several people got it going..but I am getting errors when starting the script. Can someone put me on the right track?.
Regards,Hans
Who managed to add the Medisana BS440 to Domoticz?
Forum rules
Version: xxxx
Platform: xxxx
Plugin/Hardware: xxxx
Description:
Version: xxxx
Platform: xxxx
Description:
Re: Who managed to add the Medisana BS440 to Domoticz?
Might it be an idea to post the errors and which script you are using?
You're right..sorry
I am using this script
https://github.com/keptenkurk/BS440
And this explanation
https://keptenkurk.wordpress.com/2017/0 ... -epilogue/
But because it is a little outdated here and there I am also looking at an OpenHab script which is not no outdated. And the base is the same.
https://community.openhab.org/t/use-cas ... ion/143296
I was hoping to combine these all and get it working in Domoticz. But I am not enough Linux experienced to know what works with what..etc
That's why I was hoping that someone had it working and could help me out.
So now only the errors are missing.... That might help tracking down the problem.
I my self tried the Medisana, but did not succeed getting readings on a regular basis into Domoticz.
I switched to a Xiaomi scale, which initial also gave some problems, which I could solve.
And now the Xiaomi scale works fine, and I won't switch back to Medisana.
