using percentage in lua
tiga
Post by tiga »
hello all!
i have a "type: general, percentage" device called "wtw filter levensduur (9mnd)" that is logging a filter life usage
i want to send an email when filter is 50% used and 75% used
this is what i got:
if devicechanged['wtw filter levensduur (9mnd)'] then
    waarde     = (tonumber(otherdevices_svalues["wtw filter levensduur (9mnd)"]))
    if waarde == 50 then
        commandArray[1]={['SendEmail'] = 'wtw filter#wtw filter is 50% vervuild, uitzuigen!#[email protected]' }
    if waarde == 75 then
        commandArray[1]={['SendEmail'] = 'wtw filter#wtw filter is 75% vervuild, bestel een nieuwe!#[email protected]' }
the lua script is running device triggered
but nothing happens if i have 50% or 75%
i think the error must be in this part: waarde = (tonumber(otherdevices_svalues["wtw filter levensduur (9mnd)"])) but i dont know how to fix it
or is this some kind of loop prevention couse the ['wtw filter levensduur (9mnd)'] is updated by another script?????!!!!
HvdW
Domoticz version: 2023.2
Re: using percentage in lua
Post by HvdW »
Maybe use the dump() statement for your device to see what values should be used.
Bugs bug me.
Domoticz version: 2025.1
Perhaps you can learn from your own previous topic here https://domoticz.com/forum/viewtopic.ph ... ge#p318704
