Help with Blockly...
Posted: Friday 18 October 2024 8:59
by fjuppe
I have tried to search for an answer but without success;
This Blockly block updates a parameter (0219) with fixed value = 100 and works OK. But I want to use an existing user variable instead of the fixed value in the URL. Is this possible in Blockly and what would I write as "val=" ???
Thanks a lot in advance!
Re: Help with Blockly...
Posted: Friday 18 October 2024 21:44
by solarboy
First create a new global variable in setup>user variables. Give it type "float". Then set it to 100 in Blockly using Logic>Set and Devices>User variables and choosing from the 4 options corresponding to the first letter of your variable.
Posted: Saturday 19 October 2024 10:25
by fjuppe
Thank you "solarboy" for your reply. I already have a Blockly that updates the user variable. Now, what I want to do is use thatvariable as the value ("val=") in the http request but I dont know how to correctly format it....
/fjuppe
Posted: Saturday 19 October 2024 12:14
by BartSr
not a direct answer but I would advice to use dzVents being very flexible. And yes it has a learning curve .....
Posted: Monday 21 October 2024 14:12
by fjuppe
I finally got dzVents to work. This is the code for setpoint to Husdata (heatpump interface). To set temperature, you must multiply with 10. To set 10 degrees, send 100. I dont check for same value because I dont use the timer....
		devices = { 'Set Pool Temp' },
		--timer = { 'on every 2 minutes' }
	    local setpoint = domoticz.devices('Set Pool Temp').setPoint
	    local NewParallel = (setpoint)*10
	    --local ActualParallel = tonumber(domoticz.devices('Parallel').state)
	    --if NewParallel/10 ~= ActualParallel then
	        domoticz.openURL('http://xxxx.tplinkdns.com:xx/api/set?idx=0219&val=' .. NewParallel)
	    --end
Posted: Monday 21 October 2024 14:31
by BartSr
happy it works now
once you know the basics of dzVents it's very easy and powerfull
Posted: Monday 21 October 2024 14:39
by fjuppe
Thank you for your push against dzVents…😃
