dzVents does not read parameters "devices"
sooper
Post by sooper »
I tried running a default dzVents script in Domoticz.
	    timer = {
	        'every minute'},
		devices = {
			'Alarm'
		domoticz.log('Device ' .. device.name .. ' was changed', domoticz.LOG_INFO)
The result I got
Error: dzVents: Error: (3.0.2) ...domoticz/scripts/dzVents/generated_scripts/Script #3.lua:16: attempt to concatenate a nil value (field 'name')
Re: dzVents does not read parameters "devices"
You have set 2 triggers:device and timer.
If timer is triggered the input of the execute function is not a device but a timer object. In the documentation the second object of
is called item instead of device to indicate it can be anything depending on the trigger
So if you want to continue with 2 triggers you first have to check what the trigger was, device or timer.
For example (from documentation):
            timer = { 'every 5 minutes' },
            devices = { 'myDetector' }
        if (item.isTimer) then
            -- the timer was triggered
            domoticz.devices('myLamp').switchOff()
        elseif (item.isDevice and item.active) then
            -- it must be the detector
            domoticz.devices('myLamp').switchOn()
See also the wiki for more information:
https://www.domoticz.com/wiki/DzVents:_ ... .80.A6_end
sooper
Post by sooper »
I understand now, thanks a lot.
