SONOFF ZigBee 3.0 USB Dongle Plus (ZBDongle-E)
Posted: Friday 27 September 2024 20:46
by JBN
I just bought at new SONOFF ZBDongle-E and tried to install it to Zigbee for Domoticz. The device is found, and the first try worked for a while before the plugin restarted. I then rebooted and now I get a "restart-loop" as illustrated in the logs:
I tried Elelabs tool and got:
Any advise?
- Spoiler: show
- 024-09-27 20:26:01.391 Status: Z4D: Started.
2024-09-27 20:26:01.391 Status: Z4D: Entering work loop.
2024-09-27 20:26:03.250 Status: Z4D: Initialized version 7.1, author 'pipiche38'
2024-09-27 20:26:03.274 Status: Z4D: Welcome to Zigbee for Domoticz (Z4D) plugin.
2024-09-27 20:26:03.274 Status: Z4D: Z4D requires python3.8 or above and you are running 3.9
2024-09-27 20:26:03.275 Z4D: Z4D loading PluginConf
2024-09-27 20:26:03.279 Z4D: Loading PluginConf - from Domoticz sqlite Db
2024-09-27 20:26:03.279 Z4D: /home/pi/domoticz/plugins/Domoticz-Zigbee/Conf/PluginConf-24.json timestamp is 1726245095.9585733
2024-09-27 20:26:03.280 Z4D: Dz PluginConf is older than Json Dz: 0 Json: 1726245095.9585733
2024-09-27 20:26:03.283 Status: Z4D: PluginAnalytics set to 1
2024-09-27 20:26:03.283 Status: Z4D: EnergyScanAtStatup set to 0
2024-09-27 20:26:03.283 Status: Z4D: autoServeOTA set to 1
2024-09-27 20:26:03.283 Status: Z4D: checkFirmwareAgainstZigbeeOTARepository set to 0
2024-09-27 20:26:03.283 Status: Z4D: channel set to 15
2024-09-27 20:26:03.283 Status: Z4D: filename set to /home/pi/domoticz/plugins/Domoticz-Zigbee/Conf/PluginConf-24.json
2024-09-27 20:26:03.284 Status: Z4D: pluginHome set to /home/pi/domoticz/plugins/Domoticz-Zigbee
2024-09-27 20:26:03.284 Status: Z4D: homedirectory set to /home/pi/domoticz/plugins/Domoticz-Zigbee
2024-09-27 20:26:03.284 Status: Z4D: pluginData set to /home/pi/domoticz/plugins/Domoticz-Zigbee/Data
2024-09-27 20:26:03.284 Status: Z4D: pluginConfig set to /home/pi/domoticz/plugins/Domoticz-Zigbee/Conf
2024-09-27 20:26:03.284 Status: Z4D: pluginOTAFirmware set to /home/pi/domoticz/plugins/Domoticz-Zigbee/OTAFirmware
2024-09-27 20:26:03.284 Status: Z4D: pluginReports set to /home/pi/domoticz/plugins/Domoticz-Zigbee/Reports
2024-09-27 20:26:03.284 Status: Z4D: pluginWWW set to /home/pi/domoticz/plugins/Domoticz-Zigbee/www
2024-09-27 20:26:03.284 Status: Z4D: pluginLogs set to /home/pi/domoticz/plugins/Domoticz-Zigbee/Logs
2024-09-27 20:26:03.284 Status: Z4D: SSLCertificate set to /home/pi/domoticz/plugins/Domoticz-Zigbee/certs/server.crt
2024-09-27 20:26:03.284 Status: Z4D: SSLPrivateKey set to /home/pi/domoticz/plugins/Domoticz-Zigbee/certs/server.key
2024-09-27 20:26:03.285 Status: Z4D: ControllerInRawMode set to True
2024-09-27 20:26:03.285 Status: Z4D: expJsonDatabase set to 0
2024-09-27 20:26:03.375 Status: Z4D: Checking Python modules /home/pi/domoticz/plugins/Domoticz-Zigbee/constraints.txt
2024-09-27 20:26:03.387 Status: Z4D: - charset-normalizer==2.0.11 version required 2.0.11 installed 2.0.11
2024-09-27 20:26:03.395 Status: Z4D: - zigpy==0.64.0 version required 0.64.0 installed 0.64.0
2024-09-27 20:26:03.403 Status: Z4D: - zigpy_znp==0.12.1 version required 0.12.1 installed 0.12.1
2024-09-27 20:26:03.411 Status: Z4D: - zigpy_deconz==0.23.1 version required 0.23.1 installed 0.23.1
2024-09-27 20:26:03.420 Status: Z4D: - bellows==0.38.4 version required 0.38.4 installed 0.38.4
2024-09-27 20:26:03.429 Status: Z4D: - dnspython==2.6.1 version required 2.6.1 installed 2.6.1
2024-09-27 20:26:03.437 Status: Z4D: - pyserial>=3.5 version required 3.5 installed 3.5
2024-09-27 20:26:03.447 Status: Z4D: - charset-normalizer==2.0.11 version required 2.0.11 installed 2.0.11
2024-09-27 20:26:03.456 Status: Z4D: - jsonschema==4.17.3 version required 4.17.3 installed 4.17.3
2024-09-27 20:26:03.466 Status: Z4D: - cryptography<=40.0.2 version required 40.0.2 installed 40.0.2
2024-09-27 20:26:03.467 Z4D: Installing plugin custom page /home/pi/domoticz/www/templates/Z4D.html
2024-09-27 20:26:03.467 Z4D: start_logging_thread
2024-09-27 20:26:03.468 Z4D: logging_thread - listening
2024-09-27 20:26:03.469 Status: Z4D: Please watch plugin log into /home/pi/domoticz/plugins/Domoticz-Zigbee/Logs/PluginZigbee_24.log
2024-09-27 20:26:03.485 Status: Z4D: Z4D starting with stable7-7.1.012
2024-09-27 20:26:03.499 Status: Z4D: Z4D loads ZCL Cluster definitions
2024-09-27 20:26:03.536 Status: Z4D: Z4D loaded 16 configuration from legacy database.
2024-09-27 20:26:03.538 Status: Z4D: Z4D loads 16 configuration from the local certified Db.
2024-09-27 20:26:03.854 Status: Z4D: Z4D loads 588 Certified devices from repository.
2024-09-27 20:26:03.866 Status: Z4D: Z4D loading database
2024-09-27 20:26:04.360 Status: Z4D: Z4D loads 33 entries from /home/pi/domoticz/plugins/Domoticz-Zigbee/Data/DeviceList-24.txt
2024-09-27 20:26:04.432 Status: Z4D: Z4D configured to use transport mode: ZigpyEZSP
2024-09-27 20:26:06.533 Status: Z4D: Z4D starting EZSP
2024-09-27 20:26:06.551 Status: Z4D: Z4D starts WebUI
2024-09-27 20:26:06.594 Status: Z4D: WebUI thread started
2024-09-27 20:26:06.603 Status: Z4D: WebUI Server started on 0.0.0.0:9440
2024-09-27 20:26:07.241 Status: Z4D: Plugin looks to upgrade the Certified Device package
2024-09-27 20:26:08.574 Status: Z4D: ++ Started radio ezsp port: /dev/serial/by-id/usb-Itead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_V2_2ada84a2618cee11b74dfc018acbdcd8-if00-port0
2024-09-27 20:26:08.575 Status: Z4D: ++ Use of Zigpy Persistent Db
2024-09-27 20:26:10.573 Status: Z4D: ++ EZSP Radio register default Ep
2024-09-27 20:26:12.677 Status: Z4D: ++ EZSP Configuration {'device': {'path': '/dev/serial/by-id/usb-Itead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_V2_2ada84a2618cee11b74dfc018acbdcd8-if00-port0', 'baudrate': 115200, 'flow_control': None}, 'network': {'channel': 15, 'key_sequence_number': 0, 'update_id': 0, 'channels': <Channels.CHANNEL_25|CHANNEL_20|CHANNEL_15|CHANNEL_11: 34637824>, 'key': None, 'pan_id': None, 'tc_address': None, 'tc_link_key': 5a:69:67:42:65:65:41:6c:6c:69:61:6e:63:65:30:39, 'extended_pan_id': None}, 'ezsp_config': {}, 'ota': {'enabled': False, 'z2m_remote_index': None, 'broadcast_enabled': True, 'remote_providers': [], 'allow_advanced_ota_dir': False, 'broadcast_initial_delay': 14040.0, 'thirdreality_provider': True, 'advanced_ota_dir': None, 'ledvance_provider': True, 'salus_provider': True, 'sonoff_provider': True, 'inovelli_provider': True, 'broadcast_interval': 14040.0, 'ikea_provider': False, 'z2m_local_index': None}, 'handle_unknown_devices': True, 'source_routing': False, 'topology_scan_enabled': True, 'database_path': ':memory:', 'topology_scan_period': 720, 'backup_enabled': True, 'backup_period': 1, 'startup_energy_scan': False, 'use_thread': True, 'max_concurrent_requests': 8, 'ezsp_policies': {}, 'additional_endpoints': [], 'topology_scan_skip_coordinator': False, 'watchdog_enabled': True, 'validate_network_settings': False, 'max_watchdog_failures': 4}
2024-09-27 20:26:12.680 Status: Z4D: Number of devices recently active in Coordinator = 0
2024-09-27 20:26:12.762 Status: Z4D: ++ EZSP Board Information
2024-09-27 20:26:12.766 Status: Z4D: ++ Radio manufacturer : None
2024-09-27 20:26:12.770 Status: Z4D: ++ Radio board name : None
2024-09-27 20:26:12.776 Status: Z4D: ++ EmberZNet version : 6.10.3.0 build 297
2024-09-27 20:26:12.777 Status: Z4D: ++ Protocol Version : 8
2024-09-27 20:26:12.783 Status: Z4D: ++ Network settings
2024-09-27 20:26:12.786 Status: Z4D: ++ Device IEEE : 8c:65:a3:ff:fe:52:55:7a
2024-09-27 20:26:12.788 Status: Z4D: ++ Device NWK : 0x0000
2024-09-27 20:26:12.793 Status: Z4D: ++ Network Update Id : 0x0000
2024-09-27 20:26:12.799 Status: Z4D: ++ PAN ID : 0x882C
2024-09-27 20:26:12.802 Status: Z4D: ++ Extended PAN ID : 00:21:2e:ff:ff:06:a2:48
2024-09-27 20:26:12.803 Status: Z4D: ++ Channel : 15
2024-09-27 20:26:12.811 Status: Z4D: Untested Zigbee adapter model. If this is a Sonoff USB Dongle E that is a known issue, otherwise please report to the Zigbee for Domoticz team
2024-09-27 20:26:12.812 Status: Z4D: Installer Version Number: 6.10.3.0 build 297
2024-09-27 20:26:12.815 Status: Z4D: Branch Version: ==> Unknown Silicon Labs <==
2024-09-27 20:26:12.842 Status: Z4D: Zigbee Coordinator ieee: 8c65a3fffe52557a , short addr: 0000
2024-09-27 20:26:12.845 Status: Z4D: Network state UP, PANID: 882c extPANID: 0x00212effff06a248 Channel: 15
2024-09-27 20:26:16.440 Error: Z4D: Connection lost with coordinator, restarting plugin
2024-09-27 20:26:16.460 Z4D: URL INFOS {'type': 'command', 'param': 'updatehardware', 'htype': '94', 'idx': 24, 'name': 'Z4D', 'address': '0.0.0.0', 'port': '9999', 'serialport': '/dev/serial/by-id/usb-Itead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_V2_2ada84a2618cee11b74dfc018acbdcd8-if00-port0', 'Mode1': 'ZigpyEZSP', 'Mode2': 'USB', 'Mode3': 'False', 'Mode4': '9440', 'Mode5': 'http://127.0.0.1:80', 'Mode6': '0', 'extra': 'Zigate', 'enabled': 'true', 'datatimeout': '0', 'loglevel': 7}
2024-09-27 20:26:16.467 Status: Z4D: Plugin Restart command : (REMOVED HTTP TO MAKE THE POST SAVE)://127.0.0.1:80/json.htm?type=command¶m=updatehardware&htype=94&idx=24&name=Z4D&address=0.0.0.0&port=9999&serialport=%2Fdev%2Fserial%2Fby-id%2Fusb-Itead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_V2_2ada84a2618cee11b74dfc018acbdcd8-if00-port0&Mode1=ZigpyEZSP&Mode2=USB&Mode3=False&Mode4=9440&Mode5=http%3A%2F%2F127.0.0.1%3A80&Mode6=0&extra=Zigate&enabled=true&datatimeout=0&loglevel=7
2024-09-27 20:26:16.512 Status: Z4D: Stop directive received.
2024-09-27 20:26:27.164 Z4D: onStop()
2024-09-27 20:26:27.202 Status: Z4D: Z4D Widgets usage is at 21.2% (201 units free)
2024-09-27 20:26:27.205 Status: Z4D: Z4D started with legacy Framework
2024-09-27 20:26:35.736 Status: Z4D: WebUI shutdown completed
2024-09-27 20:26:35.760 Status: Z4D: Plugin statistics
2024-09-27 20:26:35.760 Status: Z4D: Messages Sent:
2024-09-27 20:26:35.760 Status: Z4D: Max Load (Queue) : 6
2024-09-27 20:26:35.760 Status: Z4D: TX commands : 8
2024-09-27 20:26:35.761 Status: Z4D: TX failed : 8 (10.0%)
2024-09-27 20:26:35.761 Status: Z4D: TX data timeout : 0 (0.0%)
2024-09-27 20:26:35.761 Status: Z4D: TX reTransmit : 0 (0.0%)
2024-09-27 20:26:35.761 Status: Z4D: TX APS Ack : 0 (0.0%)
2024-09-27 20:26:35.761 Status: Z4D: TX APS Nck : 8 (100.0%)
2024-09-27 20:26:35.761 Status: Z4D: Messages Received:
2024-09-27 20:26:35.761 Status: Z4D: RX frame : 15
2024-09-27 20:26:35.761 Status: Z4D: RX clusters : 0
2024-09-27 20:26:35.761 Status: Z4D: RX clusters KO : 0
2024-09-27 20:26:35.761 Status: Z4D: Plugin reacting time on Tx (if ReactTime enabled)
2024-09-27 20:26:35.761 Status: Z4D: Max : 0 ms
2024-09-27 20:26:35.762 Status: Z4D: Average : 0 ms
2024-09-27 20:26:35.762 Status: Z4D: Plugin processing time on Rx (if ReactTime enabled)
2024-09-27 20:26:35.762 Status: Z4D: Max : 0 ms
2024-09-27 20:26:35.762 Status: Z4D: Operating time : 0 Hours 0 Mins 31 Secs
2024-09-27 20:26:35.764 Z4D: logging_thread - ended
2024-09-27 20:26:35.768 Z4D: Logging Thread shutdown
2024-09-27 20:26:36.413 Status: Z4D: Exiting work loop.
2024-09-27 20:26:36.470 Status: Z4D: Stopping threads.
2024-09-27 20:26:36.470 Status: Z4D: Stopped.
2024-09-27 20:26:36.471 Z4D: Worker thread started.
2024-09-27 20:26:36.471 Status: Z4D: Started.
2024-09-27 20:26:36.471 Status: Z4D: Entering work loop.
2024-09-27 20:26:38.325 Status: Z4D: Initialized version 7.1, author 'pipiche38'
2024-09-27 20:26:38.350 Status: Z4D: Welcome to Zigbee for Domoticz (Z4D) plugin.
2024-09-27 20:26:38.350 Status: Z4D: Z4D requires python3.8 or above and you are running 3.9
2024-09-27 20:26:38.351 Z4D: Z4D loading PluginConf
2024-09-27 20:26:38.354 Z4D: Loading PluginConf - from Domoticz sqlite Db
2024-09-27 20:26:38.355 Z4D: /home/pi/domoticz/plugins/Domoticz-Zigbee/Conf/PluginConf-24.json timestamp is 1726245095.9585733
2024-09-27 20:26:38.355 Z4D: Dz PluginConf is older than Json Dz: 0 Json: 1726245095.9585733
2024-09-27 20:26:38.358 Status: Z4D: PluginAnalytics set to 1
2024-09-27 20:26:38.358 Status: Z4D: EnergyScanAtStatup set to 0
2024-09-27 20:26:38.358 Status: Z4D: autoServeOTA set to 1
2024-09-27 20:26:38.358 Status: Z4D: checkFirmwareAgainstZigbeeOTARepository set to 0
2024-09-27 20:26:38.359 Status: Z4D: channel set to 15
2024-09-27 20:26:38.359 Status: Z4D: filename set to /home/pi/domoticz/plugins/Domoticz-Zigbee/Conf/PluginConf-24.json
2024-09-27 20:26:38.359 Status: Z4D: pluginHome set to /home/pi/domoticz/plugins/Domoticz-Zigbee
2024-09-27 20:26:38.359 Status: Z4D: homedirectory set to /home/pi/domoticz/plugins/Domoticz-Zigbee
2024-09-27 20:26:38.359 Status: Z4D: pluginData set to /home/pi/domoticz/plugins/Domoticz-Zigbee/Data
2024-09-27 20:26:38.359 Status: Z4D: pluginConfig set to /home/pi/domoticz/plugins/Domoticz-Zigbee/Conf
2024-09-27 20:26:38.359 Status: Z4D: pluginOTAFirmware set to /home/pi/domoticz/plugins/Domoticz-Zigbee/OTAFirmware
2024-09-27 20:26:38.359 Status: Z4D: pluginReports set to /home/pi/domoticz/plugins/Domoticz-Zigbee/Reports
2024-09-27 20:26:38.359 Status: Z4D: pluginWWW set to /home/pi/domoticz/plugins/Domoticz-Zigbee/www
2024-09-27 20:26:38.360 Status: Z4D: pluginLogs set to /home/pi/domoticz/plugins/Domoticz-Zigbee/Logs
2024-09-27 20:26:38.360 Status: Z4D: SSLCertificate set to /home/pi/domoticz/plugins/Domoticz-Zigbee/certs/server.crt
2024-09-27 20:26:38.360 Status: Z4D: SSLPrivateKey set to /home/pi/domoticz/plugins/Domoticz-Zigbee/certs/server.key
2024-09-27 20:26:38.360 Status: Z4D: ControllerInRawMode set to True
2024-09-27 20:26:38.360 Status: Z4D: expJsonDatabase set to 0
2024-09-27 20:26:38.446 Status: Z4D: Checking Python modules /home/pi/domoticz/plugins/Domoticz-Zigbee/constraints.txt
2024-09-27 20:26:38.457 Status: Z4D: - charset-normalizer==2.0.11 version required 2.0.11 installed 2.0.11
2024-09-27 20:26:38.465 Status: Z4D: - zigpy==0.64.0 version required 0.64.0 installed 0.64.0
2024-09-27 20:26:38.474 Status: Z4D: - zigpy_znp==0.12.1 version required 0.12.1 installed 0.12.1
2024-09-27 20:26:38.482 Status: Z4D: - zigpy_deconz==0.23.1 version required 0.23.1 installed 0.23.1
2024-09-27 20:26:38.491 Status: Z4D: - bellows==0.38.4 version required 0.38.4 installed 0.38.4
2024-09-27 20:26:38.499 Status: Z4D: - dnspython==2.6.1 version required 2.6.1 installed 2.6.1
2024-09-27 20:26:38.508 Status: Z4D: - pyserial>=3.5 version required 3.5 installed 3.5
2024-09-27 20:26:38.517 Status: Z4D: - charset-normalizer==2.0.11 version required 2.0.11 installed 2.0.11
2024-09-27 20:26:38.526 Status: Z4D: - jsonschema==4.17.3 version required 4.17.3 installed 4.17.3
2024-09-27 20:26:38.537 Status: Z4D: - cryptography<=40.0.2 version required 40.0.2 installed 40.0.2
2024-09-27 20:26:38.537 Z4D: Installing plugin custom page /home/pi/domoticz/www/templates/Z4D.html
2024-09-27 20:26:38.538 Z4D: start_logging_thread
2024-09-27 20:26:38.539 Z4D: logging_thread - listening
2024-09-27 20:26:38.540 Status: Z4D: Please watch plugin log into /home/pi/domoticz/plugins/Domoticz-Zigbee/Logs/PluginZigbee_24.log
2024-09-27 20:26:38.558 Status: Z4D: Z4D starting with stable7-7.1.012
2024-09-27 20:26:38.573 Status: Z4D: Z4D loads ZCL Cluster definitions
2024-09-27 20:26:38.610 Status: Z4D: Z4D loaded 16 configuration from legacy database.
2024-09-27 20:26:38.612 Status: Z4D: Z4D loads 16 configuration from the local certified Db.
2024-09-27 20:26:38.930 Status: Z4D: Z4D loads 588 Certified devices from repository.
2024-09-27 20:26:38.931 Status: Z4D: Z4D loading database
2024-09-27 20:26:39.428 Status: Z4D: Z4D loads 33 entries from /home/pi/domoticz/plugins/Domoticz-Zigbee/Data/DeviceList-24.txt
2024-09-27 20:26:39.497 Status: Z4D: Z4D configured to use transport mode: ZigpyEZSP
2024-09-27 20:26:41.725 Status: Z4D: Z4D starting EZSP
2024-09-27 20:26:41.733 Status: Z4D: Z4D starts WebUI
2024-09-27 20:26:41.771 Status: Z4D: WebUI thread started
2024-09-27 20:26:41.803 Status: Z4D: WebUI Server started on 0.0.0.0:9440
2024-09-27 20:26:42.237 Status: Z4D: Plugin looks to upgrade the Certified Device package
2024-09-27 20:26:42.814 Status: Z4D: ++ Started radio ezsp port: /dev/serial/by-id/usb-Itead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_V2_2ada84a2618cee11b74dfc018acbdcd8-if00-port0
2024-09-27 20:26:42.815 Status: Z4D: ++ Use of Zigpy Persistent Db
2024-09-27 20:26:44.706 Status: Z4D: ++ EZSP Radio register default Ep
2024-09-27 20:26:46.862 Status: Z4D: ++ EZSP Configuration {'device': {'path': '/dev/serial/by-id/usb-Itead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_V2_2ada84a2618cee11b74dfc018acbdcd8-if00-port0', 'baudrate': 115200, 'flow_control': None}, 'network': {'channel': 15, 'key_sequence_number': 0, 'update_id': 0, 'channels': <Channels.CHANNEL_25|CHANNEL_20|CHANNEL_15|CHANNEL_11: 34637824>, 'key': None, 'pan_id': None, 'tc_address': None, 'tc_link_key': 5a:69:67:42:65:65:41:6c:6c:69:61:6e:63:65:30:39, 'extended_pan_id': None}, 'ezsp_config': {}, 'ota': {'enabled': False, 'z2m_remote_index': None, 'broadcast_enabled': True, 'remote_providers': [], 'allow_advanced_ota_dir': False, 'broadcast_initial_delay': 14040.0, 'thirdreality_provider': True, 'advanced_ota_dir': None, 'ledvance_provider': True, 'salus_provider': True, 'sonoff_provider': True, 'inovelli_provider': True, 'broadcast_interval': 14040.0, 'ikea_provider': False, 'z2m_local_index': None}, 'handle_unknown_devices': True, 'source_routing': False, 'topology_scan_enabled': True, 'database_path': ':memory:', 'topology_scan_period': 720, 'backup_enabled': True, 'backup_period': 1, 'startup_energy_scan': False, 'use_thread': True, 'max_concurrent_requests': 8, 'ezsp_policies': {}, 'additional_endpoints': [], 'topology_scan_skip_coordinator': False, 'watchdog_enabled': True, 'validate_network_settings': False, 'max_watchdog_failures': 4}
2024-09-27 20:26:46.866 Status: Z4D: Number of devices recently active in Coordinator = 0
2024-09-27 20:26:46.946 Status: Z4D: ++ EZSP Board Information
2024-09-27 20:26:46.952 Status: Z4D: ++ Radio manufacturer : None
2024-09-27 20:26:46.957 Status: Z4D: ++ Radio board name : None
2024-09-27 20:26:46.968 Status: Z4D: ++ EmberZNet version : 6.10.3.0 build 297
2024-09-27 20:26:46.974 Status: Z4D: ++ Protocol Version : 8
2024-09-27 20:26:46.979 Status: Z4D: ++ Network settings
2024-09-27 20:26:46.982 Status: Z4D: ++ Device IEEE : 8c:65:a3:ff:fe:52:55:7a
2024-09-27 20:26:46.985 Status: Z4D: ++ Device NWK : 0x0000
2024-09-27 20:26:46.987 Status: Z4D: ++ Network Update Id : 0x0000
2024-09-27 20:26:46.989 Status: Z4D: ++ PAN ID : 0x882C
2024-09-27 20:26:46.991 Status: Z4D: ++ Extended PAN ID : 00:21:2e:ff:ff:06:a2:48
2024-09-27 20:26:46.995 Status: Z4D: ++ Channel : 15
2024-09-27 20:26:46.996 Status: Z4D: Untested Zigbee adapter model. If this is a Sonoff USB Dongle E that is a known issue, otherwise please report to the Zigbee for Domoticz team
2024-09-27 20:26:46.998 Status: Z4D: Installer Version Number: 6.10.3.0 build 297
2024-09-27 20:26:47.000 Status: Z4D: Branch Version: ==> Unknown Silicon Labs <==
2024-09-27 20:26:47.014 Status: Z4D: Zigbee Coordinator ieee: 8c65a3fffe52557a , short addr: 0000
2024-09-27 20:26:47.015 Status: Z4D: Network state UP, PANID: 882c extPANID: 0x00212effff06a248 Channel: 15
2024-09-27 20:26:50.301 Error: Z4D: Connection lost with coordinator, restarting plugin
2024-09-27 20:26:50.317 Z4D: URL INFOS {'type': 'command', 'param': 'updatehardware', 'htype': '94', 'idx': 24, 'name': 'Z4D', 'address': '0.0.0.0', 'port': '9999', 'serialport': '/dev/serial/by-id/usb-Itead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_V2_2ada84a2618cee11b74dfc018acbdcd8-if00-port0', 'Mode1': 'ZigpyEZSP', 'Mode2': 'USB', 'Mode3': 'False', 'Mode4': '9440', 'Mode5': 'http://127.0.0.1:80', 'Mode6': '0', 'extra': 'Zigate', 'enabled': 'true', 'datatimeout': '0', 'loglevel': 7}
2024-09-27 20:26:50.318 Status: Z4D: Plugin Restart command : http://127.0.0.1:80/json.htm?type=comma ... loglevel=7
2024-09-27 20:26:50.361 Status: Z4D: Stop directive received.
I think there is a new version, but I am uncertain it works: http://github.com/itead/Sonoff_Zigbee_D ... /NCP_7.4.3sudo python3 Elelabs_EzspFwUtility.py probe -p /dev/ttyUSB1
2024/09/27 20:19:30 Elelabs_EzspFwUtility: Generic Zigbee EZSP adapter detected:
2024/09/27 20:19:30 Elelabs_EzspFwUtility: Firmware: 6.10.3-41
2024/09/27 20:19:30 Elelabs_EzspFwUtility: EZSP v8
Any advise?
