SONOFF ZigBee 3.0 USB Dongle Plus (ZBDongle-E)
JBN
Post by JBN »
I just bought at new SONOFF ZBDongle-E and tried to install it to Zigbee for Domoticz. The device is found, and the first try worked for a while before the plugin restarted. I then rebooted and now I get a "restart-loop" as illustrated in the logs:
024-09-27 20:26:01.391 Status: Z4D: Started.
2024-09-27 20:26:01.391 Status: Z4D: Entering work loop.
2024-09-27 20:26:03.250 Status: Z4D: Initialized version 7.1, author 'pipiche38'
2024-09-27 20:26:03.274 Status: Z4D: Welcome to Zigbee for Domoticz (Z4D) plugin.
2024-09-27 20:26:03.274 Status: Z4D: Z4D requires python3.8 or above and you are running 3.9
2024-09-27 20:26:03.275 Z4D: Z4D loading PluginConf
2024-09-27 20:26:03.279 Z4D: Loading PluginConf - from Domoticz sqlite Db
2024-09-27 20:26:03.279 Z4D: /home/pi/domoticz/plugins/Domoticz-Zigbee/Conf/PluginConf-24.json timestamp is 1726245095.9585733
2024-09-27 20:26:03.280 Z4D: Dz PluginConf is older than Json Dz: 0 Json: 1726245095.9585733
2024-09-27 20:26:03.283 Status: Z4D: PluginAnalytics set to 1
2024-09-27 20:26:03.283 Status: Z4D: EnergyScanAtStatup set to 0
2024-09-27 20:26:03.283 Status: Z4D: autoServeOTA set to 1
2024-09-27 20:26:03.283 Status: Z4D: checkFirmwareAgainstZigbeeOTARepository set to 0
2024-09-27 20:26:03.283 Status: Z4D: channel set to 15
2024-09-27 20:26:03.283 Status: Z4D: filename set to /home/pi/domoticz/plugins/Domoticz-Zigbee/Conf/PluginConf-24.json
2024-09-27 20:26:03.284 Status: Z4D: pluginHome set to /home/pi/domoticz/plugins/Domoticz-Zigbee
2024-09-27 20:26:03.284 Status: Z4D: homedirectory set to /home/pi/domoticz/plugins/Domoticz-Zigbee
2024-09-27 20:26:03.284 Status: Z4D: pluginData set to /home/pi/domoticz/plugins/Domoticz-Zigbee/Data
2024-09-27 20:26:03.284 Status: Z4D: pluginConfig set to /home/pi/domoticz/plugins/Domoticz-Zigbee/Conf
2024-09-27 20:26:03.284 Status: Z4D: pluginOTAFirmware set to /home/pi/domoticz/plugins/Domoticz-Zigbee/OTAFirmware
2024-09-27 20:26:03.284 Status: Z4D: pluginReports set to /home/pi/domoticz/plugins/Domoticz-Zigbee/Reports
2024-09-27 20:26:03.284 Status: Z4D: pluginWWW set to /home/pi/domoticz/plugins/Domoticz-Zigbee/www
2024-09-27 20:26:03.284 Status: Z4D: pluginLogs set to /home/pi/domoticz/plugins/Domoticz-Zigbee/Logs
2024-09-27 20:26:03.284 Status: Z4D: SSLCertificate set to /home/pi/domoticz/plugins/Domoticz-Zigbee/certs/server.crt
2024-09-27 20:26:03.284 Status: Z4D: SSLPrivateKey set to /home/pi/domoticz/plugins/Domoticz-Zigbee/certs/server.key
2024-09-27 20:26:03.285 Status: Z4D: ControllerInRawMode set to True
2024-09-27 20:26:03.285 Status: Z4D: expJsonDatabase set to 0
2024-09-27 20:26:03.375 Status: Z4D: Checking Python modules /home/pi/domoticz/plugins/Domoticz-Zigbee/constraints.txt
2024-09-27 20:26:03.387 Status: Z4D: - charset-normalizer==2.0.11 version required 2.0.11 installed 2.0.11
2024-09-27 20:26:03.395 Status: Z4D: - zigpy==0.64.0 version required 0.64.0 installed 0.64.0
2024-09-27 20:26:03.403 Status: Z4D: - zigpy_znp==0.12.1 version required 0.12.1 installed 0.12.1
2024-09-27 20:26:03.411 Status: Z4D: - zigpy_deconz==0.23.1 version required 0.23.1 installed 0.23.1
2024-09-27 20:26:03.420 Status: Z4D: - bellows==0.38.4 version required 0.38.4 installed 0.38.4
2024-09-27 20:26:03.429 Status: Z4D: - dnspython==2.6.1 version required 2.6.1 installed 2.6.1
2024-09-27 20:26:03.437 Status: Z4D: - pyserial>=3.5 version required 3.5 installed 3.5
2024-09-27 20:26:03.447 Status: Z4D: - charset-normalizer==2.0.11 version required 2.0.11 installed 2.0.11
2024-09-27 20:26:03.456 Status: Z4D: - jsonschema==4.17.3 version required 4.17.3 installed 4.17.3
2024-09-27 20:26:03.466 Status: Z4D: - cryptography<=40.0.2 version required 40.0.2 installed 40.0.2
2024-09-27 20:26:03.467 Z4D: Installing plugin custom page /home/pi/domoticz/www/templates/Z4D.html
2024-09-27 20:26:03.467 Z4D: start_logging_thread
2024-09-27 20:26:03.468 Z4D: logging_thread - listening
2024-09-27 20:26:03.469 Status: Z4D: Please watch plugin log into /home/pi/domoticz/plugins/Domoticz-Zigbee/Logs/PluginZigbee_24.log
2024-09-27 20:26:03.485 Status: Z4D: Z4D starting with stable7-7.1.012
2024-09-27 20:26:03.499 Status: Z4D: Z4D loads ZCL Cluster definitions
2024-09-27 20:26:03.536 Status: Z4D: Z4D loaded 16 configuration from legacy database.
2024-09-27 20:26:03.538 Status: Z4D: Z4D loads 16 configuration from the local certified Db.
2024-09-27 20:26:03.854 Status: Z4D: Z4D loads 588 Certified devices from repository.
2024-09-27 20:26:03.866 Status: Z4D: Z4D loading database
2024-09-27 20:26:04.360 Status: Z4D: Z4D loads 33 entries from /home/pi/domoticz/plugins/Domoticz-Zigbee/Data/DeviceList-24.txt
2024-09-27 20:26:04.432 Status: Z4D: Z4D configured to use transport mode: ZigpyEZSP
2024-09-27 20:26:06.533 Status: Z4D: Z4D starting EZSP
2024-09-27 20:26:06.551 Status: Z4D: Z4D starts WebUI
2024-09-27 20:26:06.594 Status: Z4D: WebUI thread started
2024-09-27 20:26:06.603 Status: Z4D: WebUI Server started on 0.0.0.0:9440
2024-09-27 20:26:07.241 Status: Z4D: Plugin looks to upgrade the Certified Device package
2024-09-27 20:26:08.574 Status: Z4D: ++ Started radio ezsp port: /dev/serial/by-id/usb-Itead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_V2_2ada84a2618cee11b74dfc018acbdcd8-if00-port0
2024-09-27 20:26:08.575 Status: Z4D: ++ Use of Zigpy Persistent Db
2024-09-27 20:26:10.573 Status: Z4D: ++ EZSP Radio register default Ep
2024-09-27 20:26:12.677 Status: Z4D: ++ EZSP Configuration {'device': {'path': '/dev/serial/by-id/usb-Itead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_V2_2ada84a2618cee11b74dfc018acbdcd8-if00-port0', 'baudrate': 115200, 'flow_control': None}, 'network': {'channel': 15, 'key_sequence_number': 0, 'update_id': 0, 'channels': <Channels.CHANNEL_25|CHANNEL_20|CHANNEL_15|CHANNEL_11: 34637824>, 'key': None, 'pan_id': None, 'tc_address': None, 'tc_link_key': 5a:69:67:42:65:65:41:6c:6c:69:61:6e:63:65:30:39, 'extended_pan_id': None}, 'ezsp_config': {}, 'ota': {'enabled': False, 'z2m_remote_index': None, 'broadcast_enabled': True, 'remote_providers': [], 'allow_advanced_ota_dir': False, 'broadcast_initial_delay': 14040.0, 'thirdreality_provider': True, 'advanced_ota_dir': None, 'ledvance_provider': True, 'salus_provider': True, 'sonoff_provider': True, 'inovelli_provider': True, 'broadcast_interval': 14040.0, 'ikea_provider': False, 'z2m_local_index': None}, 'handle_unknown_devices': True, 'source_routing': False, 'topology_scan_enabled': True, 'database_path': ':memory:', 'topology_scan_period': 720, 'backup_enabled': True, 'backup_period': 1, 'startup_energy_scan': False, 'use_thread': True, 'max_concurrent_requests': 8, 'ezsp_policies': {}, 'additional_endpoints': [], 'topology_scan_skip_coordinator': False, 'watchdog_enabled': True, 'validate_network_settings': False, 'max_watchdog_failures': 4}
2024-09-27 20:26:12.680 Status: Z4D: Number of devices recently active in Coordinator = 0
2024-09-27 20:26:12.762 Status: Z4D: ++ EZSP Board Information
2024-09-27 20:26:12.766 Status: Z4D: ++ Radio manufacturer : None
2024-09-27 20:26:12.770 Status: Z4D: ++ Radio board name : None
2024-09-27 20:26:12.776 Status: Z4D: ++ EmberZNet version : 6.10.3.0 build 297
2024-09-27 20:26:12.777 Status: Z4D: ++ Protocol Version : 8
2024-09-27 20:26:12.783 Status: Z4D: ++ Network settings
2024-09-27 20:26:12.786 Status: Z4D: ++ Device IEEE : 8c:65:a3:ff:fe:52:55:7a
2024-09-27 20:26:12.788 Status: Z4D: ++ Device NWK : 0x0000
2024-09-27 20:26:12.793 Status: Z4D: ++ Network Update Id : 0x0000
2024-09-27 20:26:12.799 Status: Z4D: ++ PAN ID : 0x882C
2024-09-27 20:26:12.802 Status: Z4D: ++ Extended PAN ID : 00:21:2e:ff:ff:06:a2:48
2024-09-27 20:26:12.803 Status: Z4D: ++ Channel : 15
2024-09-27 20:26:12.811 Status: Z4D: Untested Zigbee adapter model. If this is a Sonoff USB Dongle E that is a known issue, otherwise please report to the Zigbee for Domoticz team
2024-09-27 20:26:12.812 Status: Z4D: Installer Version Number: 6.10.3.0 build 297
2024-09-27 20:26:12.815 Status: Z4D: Branch Version: ==> Unknown Silicon Labs <==
2024-09-27 20:26:12.842 Status: Z4D: Zigbee Coordinator ieee: 8c65a3fffe52557a , short addr: 0000
2024-09-27 20:26:12.845 Status: Z4D: Network state UP, PANID: 882c extPANID: 0x00212effff06a248 Channel: 15
2024-09-27 20:26:16.440 Error: Z4D: Connection lost with coordinator, restarting plugin
2024-09-27 20:26:16.460 Z4D: URL INFOS {'type': 'command', 'param': 'updatehardware', 'htype': '94', 'idx': 24, 'name': 'Z4D', 'address': '0.0.0.0', 'port': '9999', 'serialport': '/dev/serial/by-id/usb-Itead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_V2_2ada84a2618cee11b74dfc018acbdcd8-if00-port0', 'Mode1': 'ZigpyEZSP', 'Mode2': 'USB', 'Mode3': 'False', 'Mode4': '9440', 'Mode5': 'http://127.0.0.1:80', 'Mode6': '0', 'extra': 'Zigate', 'enabled': 'true', 'datatimeout': '0', 'loglevel': 7}
2024-09-27 20:26:16.467 Status: Z4D: Plugin Restart command : (REMOVED HTTP TO MAKE THE POST SAVE)://127.0.0.1:80/json.htm?type=command&param=updatehardware&htype=94&idx=24&name=Z4D&address=0.0.0.0&port=9999&serialport=%2Fdev%2Fserial%2Fby-id%2Fusb-Itead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_V2_2ada84a2618cee11b74dfc018acbdcd8-if00-port0&Mode1=ZigpyEZSP&Mode2=USB&Mode3=False&Mode4=9440&Mode5=http%3A%2F%2F127.0.0.1%3A80&Mode6=0&extra=Zigate&enabled=true&datatimeout=0&loglevel=7
2024-09-27 20:26:16.512 Status: Z4D: Stop directive received.
2024-09-27 20:26:27.164 Z4D: onStop()
2024-09-27 20:26:27.202 Status: Z4D: Z4D Widgets usage is at 21.2% (201 units free)
2024-09-27 20:26:27.205 Status: Z4D: Z4D started with legacy Framework
2024-09-27 20:26:35.736 Status: Z4D: WebUI shutdown completed
2024-09-27 20:26:35.760 Status: Z4D: Plugin statistics
2024-09-27 20:26:35.760 Status: Z4D: Messages Sent:
2024-09-27 20:26:35.760 Status: Z4D: Max Load (Queue) : 6
2024-09-27 20:26:35.760 Status: Z4D: TX commands : 8
2024-09-27 20:26:35.761 Status: Z4D: TX failed : 8 (10.0%)
2024-09-27 20:26:35.761 Status: Z4D: TX data timeout : 0 (0.0%)
2024-09-27 20:26:35.761 Status: Z4D: TX reTransmit : 0 (0.0%)
2024-09-27 20:26:35.761 Status: Z4D: TX APS Ack : 0 (0.0%)
2024-09-27 20:26:35.761 Status: Z4D: TX APS Nck : 8 (100.0%)
2024-09-27 20:26:35.761 Status: Z4D: Messages Received:
2024-09-27 20:26:35.761 Status: Z4D: RX frame : 15
2024-09-27 20:26:35.761 Status: Z4D: RX clusters : 0
2024-09-27 20:26:35.761 Status: Z4D: RX clusters KO : 0
2024-09-27 20:26:35.761 Status: Z4D: Plugin reacting time on Tx (if ReactTime enabled)
2024-09-27 20:26:35.761 Status: Z4D: Max : 0 ms
2024-09-27 20:26:35.762 Status: Z4D: Average : 0 ms
2024-09-27 20:26:35.762 Status: Z4D: Plugin processing time on Rx (if ReactTime enabled)
2024-09-27 20:26:35.762 Status: Z4D: Max : 0 ms
2024-09-27 20:26:35.762 Status: Z4D: Operating time : 0 Hours 0 Mins 31 Secs
2024-09-27 20:26:35.764 Z4D: logging_thread - ended
2024-09-27 20:26:35.768 Z4D: Logging Thread shutdown
2024-09-27 20:26:36.413 Status: Z4D: Exiting work loop.
2024-09-27 20:26:36.470 Status: Z4D: Stopping threads.
2024-09-27 20:26:36.470 Status: Z4D: Stopped.
2024-09-27 20:26:36.471 Z4D: Worker thread started.
2024-09-27 20:26:36.471 Status: Z4D: Started.
2024-09-27 20:26:36.471 Status: Z4D: Entering work loop.
2024-09-27 20:26:38.325 Status: Z4D: Initialized version 7.1, author 'pipiche38'
2024-09-27 20:26:38.350 Status: Z4D: Welcome to Zigbee for Domoticz (Z4D) plugin.
2024-09-27 20:26:38.350 Status: Z4D: Z4D requires python3.8 or above and you are running 3.9
2024-09-27 20:26:38.351 Z4D: Z4D loading PluginConf
2024-09-27 20:26:38.354 Z4D: Loading PluginConf - from Domoticz sqlite Db
2024-09-27 20:26:38.355 Z4D: /home/pi/domoticz/plugins/Domoticz-Zigbee/Conf/PluginConf-24.json timestamp is 1726245095.9585733
2024-09-27 20:26:38.355 Z4D: Dz PluginConf is older than Json Dz: 0 Json: 1726245095.9585733
2024-09-27 20:26:38.358 Status: Z4D: PluginAnalytics set to 1
2024-09-27 20:26:38.358 Status: Z4D: EnergyScanAtStatup set to 0
2024-09-27 20:26:38.358 Status: Z4D: autoServeOTA set to 1
2024-09-27 20:26:38.358 Status: Z4D: checkFirmwareAgainstZigbeeOTARepository set to 0
2024-09-27 20:26:38.359 Status: Z4D: channel set to 15
2024-09-27 20:26:38.359 Status: Z4D: filename set to /home/pi/domoticz/plugins/Domoticz-Zigbee/Conf/PluginConf-24.json
2024-09-27 20:26:38.359 Status: Z4D: pluginHome set to /home/pi/domoticz/plugins/Domoticz-Zigbee
2024-09-27 20:26:38.359 Status: Z4D: homedirectory set to /home/pi/domoticz/plugins/Domoticz-Zigbee
2024-09-27 20:26:38.359 Status: Z4D: pluginData set to /home/pi/domoticz/plugins/Domoticz-Zigbee/Data
2024-09-27 20:26:38.359 Status: Z4D: pluginConfig set to /home/pi/domoticz/plugins/Domoticz-Zigbee/Conf
2024-09-27 20:26:38.359 Status: Z4D: pluginOTAFirmware set to /home/pi/domoticz/plugins/Domoticz-Zigbee/OTAFirmware
2024-09-27 20:26:38.359 Status: Z4D: pluginReports set to /home/pi/domoticz/plugins/Domoticz-Zigbee/Reports
2024-09-27 20:26:38.359 Status: Z4D: pluginWWW set to /home/pi/domoticz/plugins/Domoticz-Zigbee/www
2024-09-27 20:26:38.360 Status: Z4D: pluginLogs set to /home/pi/domoticz/plugins/Domoticz-Zigbee/Logs
2024-09-27 20:26:38.360 Status: Z4D: SSLCertificate set to /home/pi/domoticz/plugins/Domoticz-Zigbee/certs/server.crt
2024-09-27 20:26:38.360 Status: Z4D: SSLPrivateKey set to /home/pi/domoticz/plugins/Domoticz-Zigbee/certs/server.key
2024-09-27 20:26:38.360 Status: Z4D: ControllerInRawMode set to True
2024-09-27 20:26:38.360 Status: Z4D: expJsonDatabase set to 0
2024-09-27 20:26:38.446 Status: Z4D: Checking Python modules /home/pi/domoticz/plugins/Domoticz-Zigbee/constraints.txt
2024-09-27 20:26:38.457 Status: Z4D: - charset-normalizer==2.0.11 version required 2.0.11 installed 2.0.11
2024-09-27 20:26:38.465 Status: Z4D: - zigpy==0.64.0 version required 0.64.0 installed 0.64.0
2024-09-27 20:26:38.474 Status: Z4D: - zigpy_znp==0.12.1 version required 0.12.1 installed 0.12.1
2024-09-27 20:26:38.482 Status: Z4D: - zigpy_deconz==0.23.1 version required 0.23.1 installed 0.23.1
2024-09-27 20:26:38.491 Status: Z4D: - bellows==0.38.4 version required 0.38.4 installed 0.38.4
2024-09-27 20:26:38.499 Status: Z4D: - dnspython==2.6.1 version required 2.6.1 installed 2.6.1
2024-09-27 20:26:38.508 Status: Z4D: - pyserial>=3.5 version required 3.5 installed 3.5
2024-09-27 20:26:38.517 Status: Z4D: - charset-normalizer==2.0.11 version required 2.0.11 installed 2.0.11
2024-09-27 20:26:38.526 Status: Z4D: - jsonschema==4.17.3 version required 4.17.3 installed 4.17.3
2024-09-27 20:26:38.537 Status: Z4D: - cryptography<=40.0.2 version required 40.0.2 installed 40.0.2
2024-09-27 20:26:38.537 Z4D: Installing plugin custom page /home/pi/domoticz/www/templates/Z4D.html
2024-09-27 20:26:38.538 Z4D: start_logging_thread
2024-09-27 20:26:38.539 Z4D: logging_thread - listening
2024-09-27 20:26:38.540 Status: Z4D: Please watch plugin log into /home/pi/domoticz/plugins/Domoticz-Zigbee/Logs/PluginZigbee_24.log
2024-09-27 20:26:38.558 Status: Z4D: Z4D starting with stable7-7.1.012
2024-09-27 20:26:38.573 Status: Z4D: Z4D loads ZCL Cluster definitions
2024-09-27 20:26:38.610 Status: Z4D: Z4D loaded 16 configuration from legacy database.
2024-09-27 20:26:38.612 Status: Z4D: Z4D loads 16 configuration from the local certified Db.
2024-09-27 20:26:38.930 Status: Z4D: Z4D loads 588 Certified devices from repository.
2024-09-27 20:26:38.931 Status: Z4D: Z4D loading database
2024-09-27 20:26:39.428 Status: Z4D: Z4D loads 33 entries from /home/pi/domoticz/plugins/Domoticz-Zigbee/Data/DeviceList-24.txt
2024-09-27 20:26:39.497 Status: Z4D: Z4D configured to use transport mode: ZigpyEZSP
2024-09-27 20:26:41.725 Status: Z4D: Z4D starting EZSP
2024-09-27 20:26:41.733 Status: Z4D: Z4D starts WebUI
2024-09-27 20:26:41.771 Status: Z4D: WebUI thread started
2024-09-27 20:26:41.803 Status: Z4D: WebUI Server started on 0.0.0.0:9440
2024-09-27 20:26:42.237 Status: Z4D: Plugin looks to upgrade the Certified Device package
2024-09-27 20:26:42.814 Status: Z4D: ++ Started radio ezsp port: /dev/serial/by-id/usb-Itead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_V2_2ada84a2618cee11b74dfc018acbdcd8-if00-port0
2024-09-27 20:26:42.815 Status: Z4D: ++ Use of Zigpy Persistent Db
2024-09-27 20:26:44.706 Status: Z4D: ++ EZSP Radio register default Ep
2024-09-27 20:26:46.862 Status: Z4D: ++ EZSP Configuration {'device': {'path': '/dev/serial/by-id/usb-Itead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_V2_2ada84a2618cee11b74dfc018acbdcd8-if00-port0', 'baudrate': 115200, 'flow_control': None}, 'network': {'channel': 15, 'key_sequence_number': 0, 'update_id': 0, 'channels': <Channels.CHANNEL_25|CHANNEL_20|CHANNEL_15|CHANNEL_11: 34637824>, 'key': None, 'pan_id': None, 'tc_address': None, 'tc_link_key': 5a:69:67:42:65:65:41:6c:6c:69:61:6e:63:65:30:39, 'extended_pan_id': None}, 'ezsp_config': {}, 'ota': {'enabled': False, 'z2m_remote_index': None, 'broadcast_enabled': True, 'remote_providers': [], 'allow_advanced_ota_dir': False, 'broadcast_initial_delay': 14040.0, 'thirdreality_provider': True, 'advanced_ota_dir': None, 'ledvance_provider': True, 'salus_provider': True, 'sonoff_provider': True, 'inovelli_provider': True, 'broadcast_interval': 14040.0, 'ikea_provider': False, 'z2m_local_index': None}, 'handle_unknown_devices': True, 'source_routing': False, 'topology_scan_enabled': True, 'database_path': ':memory:', 'topology_scan_period': 720, 'backup_enabled': True, 'backup_period': 1, 'startup_energy_scan': False, 'use_thread': True, 'max_concurrent_requests': 8, 'ezsp_policies': {}, 'additional_endpoints': [], 'topology_scan_skip_coordinator': False, 'watchdog_enabled': True, 'validate_network_settings': False, 'max_watchdog_failures': 4}
2024-09-27 20:26:46.866 Status: Z4D: Number of devices recently active in Coordinator = 0
2024-09-27 20:26:46.946 Status: Z4D: ++ EZSP Board Information
2024-09-27 20:26:46.952 Status: Z4D: ++ Radio manufacturer : None
2024-09-27 20:26:46.957 Status: Z4D: ++ Radio board name : None
2024-09-27 20:26:46.968 Status: Z4D: ++ EmberZNet version : 6.10.3.0 build 297
2024-09-27 20:26:46.974 Status: Z4D: ++ Protocol Version : 8
2024-09-27 20:26:46.979 Status: Z4D: ++ Network settings
2024-09-27 20:26:46.982 Status: Z4D: ++ Device IEEE : 8c:65:a3:ff:fe:52:55:7a
2024-09-27 20:26:46.985 Status: Z4D: ++ Device NWK : 0x0000
2024-09-27 20:26:46.987 Status: Z4D: ++ Network Update Id : 0x0000
2024-09-27 20:26:46.989 Status: Z4D: ++ PAN ID : 0x882C
2024-09-27 20:26:46.991 Status: Z4D: ++ Extended PAN ID : 00:21:2e:ff:ff:06:a2:48
2024-09-27 20:26:46.995 Status: Z4D: ++ Channel : 15
2024-09-27 20:26:46.996 Status: Z4D: Untested Zigbee adapter model. If this is a Sonoff USB Dongle E that is a known issue, otherwise please report to the Zigbee for Domoticz team
2024-09-27 20:26:46.998 Status: Z4D: Installer Version Number: 6.10.3.0 build 297
2024-09-27 20:26:47.000 Status: Z4D: Branch Version: ==> Unknown Silicon Labs <==
2024-09-27 20:26:47.014 Status: Z4D: Zigbee Coordinator ieee: 8c65a3fffe52557a , short addr: 0000
2024-09-27 20:26:47.015 Status: Z4D: Network state UP, PANID: 882c extPANID: 0x00212effff06a248 Channel: 15
2024-09-27 20:26:50.301 Error: Z4D: Connection lost with coordinator, restarting plugin
2024-09-27 20:26:50.317 Z4D: URL INFOS {'type': 'command', 'param': 'updatehardware', 'htype': '94', 'idx': 24, 'name': 'Z4D', 'address': '0.0.0.0', 'port': '9999', 'serialport': '/dev/serial/by-id/usb-Itead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_V2_2ada84a2618cee11b74dfc018acbdcd8-if00-port0', 'Mode1': 'ZigpyEZSP', 'Mode2': 'USB', 'Mode3': 'False', 'Mode4': '9440', 'Mode5': 'http://127.0.0.1:80', 'Mode6': '0', 'extra': 'Zigate', 'enabled': 'true', 'datatimeout': '0', 'loglevel': 7}
2024-09-27 20:26:50.318 Status: Z4D: Plugin Restart command : http://127.0.0.1:80/json.htm?type=comma ... loglevel=7
2024-09-27 20:26:50.361 Status: Z4D: Stop directive received.
Now I am curious about the firmware version and if I got the correct one. I asume this is the version: 6.10.3.0 build 297
I tried Elelabs tool and got:
sudo python3 Elelabs_EzspFwUtility.py probe -p /dev/ttyUSB1
2024/09/27 20:19:30 Elelabs_EzspFwUtility: Generic Zigbee EZSP adapter detected:
2024/09/27 20:19:30 Elelabs_EzspFwUtility: Firmware: 6.10.3-41
2024/09/27 20:19:30 Elelabs_EzspFwUtility: EZSP v8
I think there is a new version, but I am uncertain it works: http://github.com/itead/Sonoff_Zigbee_D ... /NCP_7.4.3
Any advise?
habahabahaba
Domoticz version: 2024.4
Re: SONOFF ZigBee 3.0 USB Dongle Plus (ZBDongle-E)
Post by habahabahaba »
So if you just bought the new SONOFF ZBDongle-E you have the older one that worked?
Did you just replace them or reinstall dongle and plugin?
JBN
Post by JBN »
I have an old Conbee II and simply changed the settings in the plugin. From what I have read in other threads that should work and giving me the opportunity to keep all sensors (and if needed simply re-pair with the plugin again). Currently I am running the Conbee II. I am changing sensor for two reasons; to see if my network reach and stability improves and to be more "future proof".
But perhaps I should reset the controller and try again if the firmware version is one that should work out-of-the-box.
When you change the controller stick in Z4D you will have to pair all devices with the new stick. As the ID of the devices will stay the same all connected Domoticz devices will become active again.
But the plugin should not go into a loop while starting the plugin with the new controller.
But this line seems strange. I don't know what it means:
JBN
Post by JBN »
I got it to work (I hope). I simply did a reset of the controller (using another PI and a fresh install of Z4D) and then started to re-pair all the sensors. 16 out of 32 done and the plugin seem to be stable thus far.
habahabahaba
waltervl wrote: Saturday 28 September 2024 13:25 2024-09-27 20:26:46.996 Status: Z4D: Untested Zigbee adapter model. If this is a Sonoff USB Dongle E that is a known issue, otherwise please report to the Zigbee for Domoticz team
Thats normal issue for Dongle E-version. Have the same and everything works
WouterO
Post by WouterO »
Yep, same here, including the ‘untested Zigbee adapter model’ message. Rest assured: after you paired your sensors properly, the Sonoff dongle E is a fine and reliable device, of course also thanks to the fine Z4D plugin of pipiche
