Time before logout Topic is solved
Time before logout
When I log in domoticz, I need to log again about every day.
It is a pity because I am permanently displaying a custom weather page on a tablet, and it is boring to have to login almost every day. In addition, when I am logged out, the page freezes without warning, and it takes me some time to realize that the page is no longer updated.
Is there a way to inhibit the auto logout? I declared my local network as a trusted network, but it changed nothing.
- Domoticz version: 2024.7
Re: Time before logout
Perhaps clear your cookies.
You should nog login if your network is in trusted network. Or make sure the IP adresses in the trusted network are formatted and separated correctly and without spaces.
If incorrect the trusted network will not be recognized.
Thank you waltervi,
I actually had something wrong in the trusted network syntax.
It now works seemlessly.
- Domoticz version: 2020.2
This may be a very silly question, but I've tried and have not found the answer.
When I go into Domoticz, it asks me for a userid/password. Fine, I can log in.
But after a while of inactivity, I am logged out. Again, fine.
But how can I log in again? I cannot find a button for this...
Hans
On a 2020.2 version? Start with clearing your browser cache, including all cookies...
Sorry, no. The 2020.2 version is my current server. The login problem is on a new server with more recent (
Hans
If you have 2 servers be sure you do not go in the browser to the 2 different servers.
Go to the test/new server only with a browser session in private/incognito mode.
Ah, good point. During migration, I will want to log into the two servers at the same time, to check settings etcetera. Would it solve the issue if I use two different browsers? Edge, Firefox, for instance?waltervl wrote: ↑Friday 22 November 2024 10:42If you have 2 servers be sure you do not go in the browser to the 2 different servers.
Hans
Yes 2 different browsers would also help.
