The raw data sent by MQTT Gateway is rounded to the closest first decimal digit for electricity usage device Topic is solved
Forum rules
Version: xxxx
Platform: xxxx
Plugin/Hardware: xxxx
Description:
meal
Domoticz version: 2024.7
Post by meal »
Context :
Version: 2024.7 (build 16178)
Build Hash: bc750e2df
Compile Date: 2024-08-07 15:43:48
dzVents Version: 3.1.8
Python Version: 3.9.2 (default, Feb 28 2021, 17:03:44) [GCC 10.2.1 20210110]
I am using MQTT Auto Discovery Client Gateway with LAN interface along with Z-Wave JS UI to control my ZWAVE devices configuration.
I have installed a Home Energy Meter - Gen5 ZW095 from AEONS Labs to collect the electricity usage in a usage device directly read from hardware device (Type=243, SubType=29).
Issue :
The raw data sent by MQTT Gateway is rounded to the closest first decimal digit (483 --> 500 or 524-->500).
For example the information read from MQTT Explorer is :
"time": 1726212707587,
"value": 12955.483,
"nodeName": "Compteur Central",
"nodeLocation": "Compteur Electrique"
or
"time": 1726212707982,
"value": 12955.524,
whereas in Domoticz I get 12955.500 kWh in the consumption device.
My question is how can I control the rounding process or even get directly the raw data from MQTT Gateway to Domoticz KWH devices.
Many thanks for your replies
BR
meal
meal
Re: The raw data sent by MQTT Gateway is rounded to the closest first decimal digit for electricity usage device
Post by meal »
The issue has been fixed.
See MQTTAutoDiscovery sensor update generates a loss of precision in the measure #6168
BR
meal
