Hello everyone
I post my message here because it seems that I have the same issue than the previous one mentioned above.
After scouring the forums and testing several solutions, I’m still struggling to get Domoticz to recognize my RFXcom (USB) "antenna."
Here is my setup:
- Raspberry Pi Model 3B+ running Raspberry Pi OS 13 Trixie (latest version to date)
- Domoticz (version 2026.2) installed via Docker (using a tutorial from Raspberry Tips)
- RFX(COM)trx433XL USB antenna (firmware updated via RFXflash to ProXL1 1052—which I assume is the latest: RFXtrx433XL_ProXL1_1052.hex). Verified in RFXmanager: the RFXcom is perfectly recognized, and the version is detected correctly. Everything looks good there.
So far, the Raspberry Pi setup has worked perfectly.
It recognizes the RFXcom when connected:
(lsusb: ID 0403:6015 Future Technology Devices International, Ltd Bridge(I2C/SPI/UART/FIFO))
However, in Domoticz > Setup > Hardware:
* Enabled = YES
* Name = RFX
* Type = RFXCOM - RFXtrx433 USB 433.92MHz Transceiver
* Serial Port: (always empty) >>> my antenna isn't detected (see attached image).
Yet, there are no issues in RFX Manager or RFX Flash (where it is identified as "COM5").
I’ve tried using different browsers (Firefox, Chrome, etc.) and restarted all the machines... but nothing works.
If anyone has encountered this issue before and has any ideas, I’d love to hear them.
Thanks in advance. Have a great day, everyone.
