Error : "Error: Error opening SQLite3 database: unable to open database file"
Posted: Monday 02 September 2024 13:18
by reza
hi guys
version 2024.4
raspberry pi 4
some times when i unplug/plug power supply of raspberry , domoticz go to offline , when i want run this manually with this command "./domoticz" i have this error :
Of course, I have made a change in Raspberry. After all the settings in domoticz, I put my sd card in read-only mode. Could it be because of this or is the problem from somewhere else?
Re: Error : "Error: Error opening SQLite3 database: unable to open database file"
Posted: Monday 02 September 2024 14:30
by willemd
reza wrote: ↑Monday 02 September 2024 13:18
hi guys
version 2024.4
raspberry pi 4
I don't think "./domoticz" is the way to start domoticz.
Try "sudo service domoticz start"
(not sure of the sudo is needed)
Posted: Monday 02 September 2024 15:41
by reza
[/quote]
[/quote]
my domoticz is in startup and always auto start. but some time with unplug/plug or reboot can not auto start and i check with ./domoticz for see errors. i see i have this error . after several reboot or several unplug/plug again auto startup domoticz and worked. but this is not true and Annoying
Posted: Monday 02 September 2024 20:29
hi guys
version 2024.4
raspberry pi 4
If your Domoticz database is also on that read-only sd card than this probably is the reason your Domoticz will not work....
Posted: Thursday 05 September 2024 16:09
by reza
waltervl wrote: ↑Monday 02 September 2024 20:29
[/quote]
I do read-only for protect sd card (stop crash SD)
so are there any solution for protect sd card?
Posted: Thursday 05 September 2024 16:44
The database needs to be updated somehow on a disk. So you need a writable disk. You could invest in adding an SSD to your Pi. Or use an high quality SD
